2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum 2 Series Active Tourer Discussions coding F46 with E-sys
      12-23-2015, 06:13 AM   #1
kevinproost
Drives: F34 GT
Hi
i'm trying to code a F46 (Active gran tourer)
with E-sys.
but i don't know with target i should use.
i always get error's.
but for a F31 its working flowless.
kind regards
      01-07-2016, 02:30 PM   #2
Hugo_RSf
Drives: Serie 2 Active tourer (F45)
Interested also. Anyone?
      01-14-2016, 05:22 AM   #3
n3xT
n3xT's Avatar
Belgium
Drives: 218D GT
hello,
the target is F56.
The F45/46/48 based on the Mini (front wheel drive etc.).
here's the coding sheat.
https://docs.google.com/spreadsheets...bnw/edit#gid=0
i'll try to make some coding of mine this week if i have time.
Regards
Alex
      01-17-2016, 05:49 PM   #4
Hugo_RSf
Can you please tell us the config for coding F45/F46?
I mean, i heard some people saying that some E-SYS version is better, etc...
      01-21-2016, 05:37 AM   #5
n3xT
n3xT's Avatar
Belgium
Drives: 218D GT
on mine F46 07/2015
i used E-Sys v.3.27.1 & v.57.3_PSdZData_Lite
an was able to vo coding 6NS easily.
      01-21-2016, 05:44 AM   #6
Hugo_RSf
Thx N3xT. What about another codings? Only vo?
I have the same e-SYS version (build 44813) but a lower version of pSdZData (57.1.001). Any problem?
Bbtw, the 6NS vo coding, (Enhanced Bluetooth, right?) is for what in F45/F46? Bt Streaming we already have it by default. Is the usb video playback capability?
      01-21-2016, 12:17 PM   #7
n3xT
n3xT's Avatar
Belgium
Drives: 218D GT
yes 6NS is for EBT..
for me the interesting feature was the ability to connect 2 phones the same time in the car and the office menu to read sms/imessage/watsapp/messenger directly in the NBT.
for another coding i'll try soon when have time.. maybe tonight if it will not be too cold
i'm curently on the way to create a mix of the F22 cheat sheet and the F56 cheat sheet to have a more clear sheet for our car !
      01-21-2016, 01:24 PM   #8
Hugo_RSf
I see...
Thanks for posting. I am waiting for my cable to try some coding.
We have to share cause there are very little info on F45/F46.
Btw, do You know how to remove the center and gear console?
      02-09-2016, 10:54 AM   #9
mekatu
Drives: f45 218 i 2014
Airbag Removal F45 AT
Hi ,
I am planning to retrofit cruise control to my 218i AT. I have just ordered the switch with cruise control (BMW part no: 61-31-9-263-551) and will try to install the switch and code accordingly.
However, I do not know how to easily remove the airbag from the steering wheel. (the sport steering wheel is I guess a new type used in new BMWs, different from F30 and F20)
To be honest, I am also a beginner for the coding part, I rely on the below guidance which I found for F20 and F30 and assuming it would be same for my car.
Any help would be very much appreciated on airbag removal and coding.
Coding:
Before you do this coding you must already know how to do coding, please search Google
on how to do or where to get the esys software/cable. I only let you know the step and ECU to do
FA coding
FA Coding:
1. Launch esys and connect to your car
2. Select expert mode
3. Read and activate FA (add option 544)
4. Read SVT
5. Select and code the following ECU
a. FEM
b. ICM
c. KOMBI
6. If you want “LIM” function, you will need to do FDL coding per the table below. This will
allow “SET” button to act like “LIM” button so that you get both LIM and Cruise control
functions.
CAFD_00000760-007-000-026 KOMBI 3003 SLD_ENABLE aktiv
CAFD_0000067B_002_003_139 ICMQ 3000 C_SLD_Funktion aktiv
CAFD_0000067B_002_003_139 ICMQ 3000 C_Umschaltung_ACC_DCC > zugelassen
      02-09-2016, 11:27 AM   #10
Hugo_RSf
I think that The platform for coding F45/46 is mini F56, not F20/30.
      02-27-2016, 02:52 PM   #11
mekatu
Retrofitting Cruise Control - Not able to code it
Hi All,
Recieved my cable and cruise control switch today for my 2014 Nov- F45 Active Tourer. Installed the steering wheel switch without any problem.
But while coding;
Added the 544 in SALAPA Element, Saved Changes, Calculated FA, Saved the new FA, Loaded the saved FA and calculated the FA again, wrote FA FP.
Then Read and Activated FA and Read ECU (Read SVT gives error message therefore I used Read ECU) in order to VO Code Kombi, FEM and ICM.
However I could not find KOMBI, FEM and ICM. Therefore Selected each ECU under the tree and coded all of them. (I received one error message due to coding DME ECU while engine is on, but fixed it later)
There is no warning light on the dashboard now, but the retrofitted Cruise Control does not work. LIM button is still working on the other hand.
Any idea what is going on and what I messed up?
Here are the ECUs under SVT tree: ACSM2(1),BDC_BODY(40),BDC_GW(10),BKOMBI(60),DME_BA C(12),DSC2(29),EGS(18),EPS(30),FLE(43),FLE(44),FZD (56),HKFM(d),HU_ENTRYNAV(63),ICAM2(6),IHKA3(78),PM A2(2c),TCB(61),ZBE3(67)
Thanks
      02-27-2016, 04:53 PM   #12
Hugo_RSf
What platform do You use? F20/30 or F56?
      02-28-2016, 09:00 AM   #13
mekatu
F56.
      03-18-2016, 04:13 AM   #14
mekatu
F45/F46 ncd files
My cruise control retrofit still not working.
Anyone in the forum owns F45 or F46 with the cruise control (544) option who can share the ncd files so that I can compare those with mine to see what is missing on my F45?
Thanks in advance.
      03-25-2016, 09:11 AM   #15
mekatu
Finally solved my problem and completed cruise control coding. Knowing that information on F45 and F46 is limited on the web I have prepared a DIY Guide for those who want to install the dynamic cruise control on their F45/F46.
Here is the link:
https://www.dropbox.com/s/fln6jgy54m..._Rev0.pdf?dl=0
      04-11-2016, 12:18 PM   #16
bulletrs
M-OCD
bulletrs's Avatar
Netherlands
17
Drives: BMW M235i
Hi,
I have also coded 6NS to the car and imported the fsc code for voice control. Everytyhing works fine except the sms/imessage/whatsapp/messenger in my idrive? I have an iphone 6 and i can not get this in idrive. Any ideas?
      05-06-2016, 02:11 PM   #17
mekatu
I have coded 6NS - Enhanced Bluetooth to my F45 218i 2014. Office menu and two simultaneous phone pairing is active. No problem with iDrive at all.
bulletrs;
In order to activate messages with an iPhone (Android works seamless) see that link:
http://f30.bimmerpost.com/forums/sho...d.php?t=895090
Bu the way, I have managed to activate SMS messages but not the e-mails yet. I will try based on that link.
But the other issue (if it is an issue) is;
When tried to update the software over USB with the file that I downloaded from BMW web site by using my car's VIN, it says "the update is not compatible with the car". Before coding 6NS, I was able to update with the same software (UPD07012.bin). It seems it is because of the 6 NS addition but how can I find the proper update software, if any?
2addicts
