Burger Tuning 15mm & 12mm spacers with lug nuts
12-20-2015, 11:54 PM | #1 |
43
Rep 206
15mm and 12mm burger tuning spacers with extended lug nuts for sale. Little bit of surface rust as to be expected but you can't see them with the wheels on anyway. Shipping at buyers expense. $150 or best offer for all of it. Thanks. |
12-26-2015, 11:06 PM | #4 |
43
Rep 206
Yes still available, see the pictures for condition, a little bit of surface rust, but function perfect. Taking a wire brush to them would probably clean them up pretty good, or that plus painting them. You can't see them once the wheels are on so the surface rust isn't a big deal. It's is $150 total for all of them.
01-07-2016, 07:56 PM | #7 |
60
Rep 387
Will they fit my stock suspension without rubbing? My wheel and tire sizes are:
18 x 8.5 et 30 18 x 9.5 et 35 225/40/18 255/35/18 If so, I'd be interested at $130 |
01-09-2016, 12:37 PM | #8 |
43
Rep 206
Sorry for the late response, they are still available. I was running them with style 162's 18x8 in the front, 18x8.5 in the rear. 225/40/18 front, and 255/35/18 rear with no rubbing on sport suspension. You have the same size tires so I would think that they would work, but I am not sure with the wider wheel? I attempted to use them with my new setup, 19x8.5 front, 19x9.5 rear, 245/35/19 front, 275/30/19 rear, and they would rub in the rear on big bumps, but that is a significantly bigger tire.
01-09-2016, 04:09 PM | #9 | |
60
Rep 387
I wonder if that's the difference between rubbing or not. I'm also on the standard sport package suspension. I'm open to fender rolling if necessary but I'd prefer to not risk chipping and cracking the paint. I'll take the entire set for $130 shipped to 67212. Thoughts? |
01-09-2016, 04:17 PM | #10 |
43
Rep 206
My tires barely rubbed the inside of my fender, so if yours are .8 inches smaller I think you should be fine, but of course that is your call. I would be willing to take $130 shipped. Ill PM you more details.
