1/4 mile, four comparisons
12-12-2015, 12:21 AM | #1 |
413
Rep 1,286
I went back to the drag strip tonight for the fourth time to see how my car has progressed with the mods that I have done. As a recap, I have an e92 automatic N51 which that has a weight of 3580 pounds with a driver and a full tank of gas. The drag strip has an elevation of 1,250 feet above sea level. The comparison below is an average of at least four passes that I made each time at the track.
Stock with PE and Dinan Ram Air Intake: 60 foot time: 2.33 ET: 15.40 MPH: 92.33 Same as above but with AA tune: 60 foot time: 2.59 ET: 15.49 MPH: 94.13 Note: my ET was off because of additional wheel spin as a result of the AA tune, which I did not experience prior, but please note the increase in MPH. Same as above but with MFactory LSD: 60 foot time: 2.33 ET: 15.17 MPH: 92.85 Note: While my 60 foot time improved, as well as my ET, there was a fall off in MPH. Same as above but with AFE catted headers: 60 foot time: 2.39 ET: 14.95 MPH: 94.38 Note: I made seven runs but this is the average of my four best, as I had a huge issue with tire spin and had to adjust my launch. three of the four runs were in DS manual mode, which means I launched in first gear, with the exception of one run, tire spin was through first and second gear. DS mode in automatic mode proved to be the best option, which means I was launching in second gear. The tire spin was excessive, even with the LSD, and was difficult to manage. For those of you that are drag strip savvy, you will recognize that my 60 foot times suck. Anyway, I hope you find my analysis somewhat entertaining and interesting. Oh, I think my drag strip days are done and my focus will be on HPDE's, which I enjoy a lot more.
2012 Jet Black 328i Coupe / ESS Tuning Gen. 2 Supercharger / Evolution Racewerks Oil Cooler / BMS Oil Catch Can / BMW Performance Exhaust with Dinan Y Pipe / Eibach Pro Kit Springs / Koni FSD Shocks / MFactory LSD & Differential Bushings / Performance Rear Trailing Arms / BMW Performance Strut Brace / Stop Tech Slotted Rotors / Hawk HPS 5.0 / SS Brake Lines / Brass Guide Pins / M3 Front Control Arms, 28 MM FSB, Engine Cowl, and DCT Paddle Shifters / Michelin PSS / APEX ARC-8
12-12-2015, 06:56 AM | #2 |
255
Rep 2,547
interesting Tom, but I think these cars are made for long curvy roads and bombing down freeways at hight rates of speed! Not for 1/4 mile bursts, that is an American car thing.
12-12-2015, 08:31 AM | #3 |
2465
Rep 9,004
Nice data, but I feel like a good/better set of tires (or less PSI in your current) would do you more justice. With that MPH, you should be mid 14's...
12-12-2015, 08:35 AM | #4 |
81
Rep 525
so if I understand correctly the MFactory LSD makes you lose some power? Because more whp is loss considering power is distributed more evenly between wheels? Just assuming trying to understand why you lost power going lsd.
12-12-2015, 09:31 AM | #5 |
413
Rep 1,286
The data would suggest a power loss to the rear wheels with the fall off in MPH as a result of the LSD. I suppose it is plausible in a lower horsepower car. Other than that, I don't have an explanation.
12-12-2015, 09:32 AM | #6 |
413
Rep 1,286
Agreed!
12-12-2015, 10:06 AM | #7 |
2465
Rep 9,004
12-12-2015, 10:11 AM | #8 |
45
Rep 168
Drives: Black 2011 BMW 328i xdrive
I find it interesting that you did a 15.40 with the PE and dinan intake. I did my first 1/4 mile drag day this summer and averaged 15.50 with my best being 15.43 completely stock.
12-12-2015, 11:12 AM | #9 |
413
Rep 1,286
12-12-2015, 11:15 AM | #10 |
413
Rep 1,286
A lot of variables play into 1/4 mile times. Do you have a N51 or a N52?
12-12-2015, 12:52 PM | #11 | |
45
Rep 168
I have the N52. Canadian (US) 328xi. I should find my slips and see what my 600s were. Just wondering if the fact that I was so close to your times had anything to do with my launch in the x-drive. It's possible I just got off the line faster. I think my speed was sub-90mph |
12-12-2015, 12:57 PM | #12 |
45
Rep 168
Found my slips. Best run was as follows:
Reaction: 0.765 60 foot: 2.369 330 foot: 6.567 660 foot: 10.025 MPH1: 70.81 990 foot: 12.892 Finish: 15.445 MPH2: 88.89 Wasn't worrying about reaction time, as I was not competing for anything. Edit: mine is x-drive and I have the 6spd manual. Edit 2: I also think my car is closer to 4k pounds with driver and fuel. I think empty weight is like 38-something |
12-12-2015, 01:05 PM | #13 | |
2465
Rep 9,004
This reminds me In need to get some baseline numbers myself |
12-12-2015, 01:33 PM | #14 |
996
Rep 2,287
[QUOTE= exception of one run, tire spin was through first and second gear.
[/QUOTE] Wait a minute here, Let me get this straight. You have a 3,600 LB car with an automatic, LSD rear end and a three liter motor. I don't understand how you can have that much wheel spin. I can see launch control being important but once you get rolling, these cars don't have enough power to break the tires loose all the way into and through second. Something does does not sound right, What type of tires are you running? Were the tires Cold and or over inflated? |
12-12-2015, 01:36 PM | #15 | |
2465
Rep 9,004
12-12-2015, 01:54 PM | #16 |
45
Rep 168
I only get a squeek out of mine, being awd.
12-12-2015, 01:56 PM | #17 | |
45
Rep 168
12-12-2015, 02:22 PM | #18 | |
3973
Rep 7,215
12-12-2015, 04:40 PM | #19 |
413
Rep 1,286
Yes, I let the car shif itself so it was shifting at the redline. I did ease it off the line a few times, which eliminated the tire spin but the result was a slighty slower 60-foot time. I think 5th gear, but honestly I wasnt paying attention to the gear selector indicator. However, the last shif twas just prior to the finish line. If I had a manual transmission I would have held in that gear without shifting because I am so close to the finish line.
12-12-2015, 05:32 PM | #20 | |
413
Rep 1,286
Another potential issue with my tires is that I have done two HPDE's with them for a total of 10 sessions so they have heat cycled quite a bit, which can affect their traction.
12-12-2015, 09:53 PM | #21 |
36
Rep 332
Drives: 2014 F32 428I Xdrive (N26)
My e92 328i 1/4 mile best time was 15:39, completely stock!
12-12-2015, 09:56 PM | #22 |
36
Rep 332
