12-09-2015, 02:13 PM | #1 |
Rep 11
BMS stage 1 - engine sputtering
i've been running a bms stage 1 for about 6 months now and over the past few weeks the car seems low on power and under hard acceleration i get some sputtering. the car is a 6 spd 228i sport. anyone had similar issues? not sure if the stage 1 is causing the issue or something else. i haven't unplugged it yet to see if the car runs any differently.
thanks... |
12-09-2015, 03:25 PM | #2 | |
Joint Chiefs of Staff
24094
Rep 190,631
If the spark plugs are old, they start having problems keeping up with the extra boost. Replacing them with new spark plugs fixes this issue, it is very common by the way
12-10-2015, 07:15 AM | #3 | |
IG @bmwF9xG80
3812
Rep 7,592
My N20 came with 11,000 miles and I Drove 14,000+ miles on RaceChip Ultimate on stock plugs before upgrading to ECU Flash & then another 1,000 miles before upgrading to S55 plugs. I ran RC at stock setting (equivalent to BMS Stage1 boost) 19, 20, 21 and up to 22 with no sputtering. This is only common with JB4 or ECU Flash since they are tuned higher than stage1 can be be more aggressive for the engine.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
12-10-2015, 07:46 AM | #4 | |
204
Rep 757
12-10-2015, 08:02 AM | #5 | |
432
Rep 887
Drives: Enzo F23 228i
12-10-2015, 01:23 PM | #6 | |
24094
Rep 190,631
This has nothing to do with with what tune you use and is not even car specific. More boost = more pressure on the spark plugs = more likely to start misfiring if they are old. The higher the boost the earlier the issue shows up, that being said eventually it will start misfiring even on stock boost
12-10-2015, 02:56 PM | #7 | |
Rep 11
What plugs do you recommenced? Sounds like a pretty easy fix. Thanks, -jb |
12-10-2015, 02:57 PM | #8 | |
24094
Rep 190,631
If it turns out to be your plugs, just replace them with OE Bosch plugs
12-13-2015, 07:19 AM | #9 | ||
M POSTER
132
Rep 516
Also ROBNYC what do you guys mean by sputtering? |
12-13-2015, 09:33 AM | #10 | |
IG @bmwF9xG80
3812
Rep 7,592
But I thought he was prob relating to hesitation
12-13-2015, 06:39 PM | #11 |
M POSTER
132
Rep 516
What exactly have you dome to your car now Rob? Is it stage 2? Im worried about pushing the N20 to past RC (stage 2 etc)
