11-28-2015, 11:36 AM | #1 |
Rep 28
ECU tuning N57 diesel engine
I am looking at installing Snow Performance methanol/water injection system as I see that it will take down the EGT (Exhaust Gas Temperature) in a fairly cost-efficient way.
If you get to high EGT's then you will actually fry your exhaust turbo turbine as it will not get red, but blue hot and the flanges will melt and the whole thing will go unbalaced and total turbo failure. With methanol/water 50/50 ratio you have a later ignition and denser air and more fuel in the cylinder. The BMW M4 pacecar video is probably common knowledge here: BMW Water injection M4 Pace car (gasoline) Diesel Water/Methanol injection I am putting in about 1200 USD for the water injection system from Snow performace with mounting and 500-1000 USD for the ECU tuning/dynometer (4-wheel drive remember) in budget. My aim is to maintain EGT and have about 380 HP and 700 Nm as the ZF gearbox is limited for that amount of torque. Changing standard RTF tires for Michelin Pilot sport 255s and 275s on 19" should be less rotation weight, better grip and cooler looks too. I already have a M Performance dual Exhaust and hence less pressure behind the turbos, but I will leave the particle filter on. Cold Air intake seems to me be a total waste of time and money. If you want cooler air, go for a race-grade intercooler then. Any suggestions for a better intercooler to the 435d? I need standard numbers and improved numbers, not just opinions.
F32 432d xDrive 2015
11-28-2015, 11:45 AM | #2 |
Rep 28
12-06-2015, 12:38 AM | #3 |
IG @bmwF9xG80
3810
Rep 7,594
Good luck keep us posted
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
12-09-2015, 04:29 AM | #4 |
3486
Rep 9,709
Why?
Diesel runs a much lower EGT than petrol in the first place (The reason VNT is OK on diesels but not on petrols) . And as there are no known issues with the frying you talk of on a 335d, so I do wonder why you are choosing to go down this route.... There seems to be many 335d's mapped or fitted with tuning boxes that get around the numbers you talk about with no reported issues. |
12-09-2015, 10:57 AM | #5 | |
Curmudgeon and Pedant
690
Rep 3,489
The TDIwyse guy knows his shit and posted this link: http://www.bankspower.com/techarticl...t-is-important TDIwyse has got his 335d (M57) to run an 11.8s 1/4 mile - he's posted a couple threads (on e90post and bimmerfest) about his mods. That's on his daily driver. |
12-10-2015, 05:05 AM | #6 | |
3486
Rep 9,709
Anyway, it's his money and car, so who am I to comment.... |
12-21-2015, 01:32 PM | #7 | |
Rep 28
630 Nm. With water/metanol injection I get better fuel economy, less emissions and still have a car that is street-normal. Removing DPF is not an option in my book. I am not t h a t keen in getting further and the original gear box takes 700 Nm good enough for me.
12-21-2015, 01:55 PM | #8 | |
Rep 28
