11-28-2015, 07:29 AM | #1 |
65
Rep 365
Configure comfort mode
Have coded configure sport on my car and it works without issue.
Does anyone know if you can do the same for comfort? Essentially what I want is to have a shorter throttle pedal in comfort mode |
11-29-2015, 12:08 AM | #2 |
30
Rep 115
How have you configured sport mode?
Current: F82 M4 Comp '19 Previous: F36 440i M Sport '18 Previous: F32 430d xDrive M Sport '15 Previous: F30 320d M Sport '14 & E81 118d M Sport '09 |
11-29-2015, 05:26 AM | #3 |
65
Rep 365
Changed the below two:
Module = HU_NBT 3000, Section = Macro_fds, New Value = popup_and_config, Default = popup_only Module = ICM 3000, Section = ICMKOD_B_SPORTINDIVIDUALISIERBAR, New Value = ein (01), Default = aus (00) (Optional for HU_CIC) Last edited by rednose; 11-29-2015 at 05:35 AM.. |
11-29-2015, 07:14 AM | #4 |
30
Rep 115
Ah I see, this is the menu which allows for drivetrain/chassis or both to be set isn't it?
I was hoping it was progress on the ability to customise the individual aspects :P
11-30-2015, 11:49 AM | #6 | |
14
Rep 56
The feature you have coded is also available in regular production cars without any coding. The feature you want cannot be coded because it doesn't exist(or nobody found it). |
