BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Felpro valve cover gasket?
      11-25-2015, 08:29 AM   #1
slenser
9
Drives: 2010 535i M Sport
Has anyone tried this yet?
FEL-PRO VS50867R http://www.napaonline.com/Catalog/Ca...67R_0520234357
Felpro is one of the most trusted names in gaskets and BMW's always ends up leaking, so I'm wondering if this would be a good choice in replacing my VCG.
If I was working with an American car I wouldn't even hesitate.
      11-26-2015, 09:22 PM   #2
slenser
9
Due to the overwhelming response I decided to get it. I'll keep you guys posted on my results.
      11-26-2015, 11:04 PM   #3
BashShah
298
Drives: 2012 335i Sedan
Please do..... Looking forward to a tread on what gasket is better.
DN
      11-28-2015, 02:55 PM   #4
slenser
9
I just picked it up and am waiting for the engine to cool a bit. I think I'll do my oil filter housing today as well. I just hope nothing breaks or I'll have to wait until Monday to finish it.
      11-28-2015, 08:22 PM   #5
BashShah
298
I had to do my oil filter housing gasket twice.
Cause it was and is a poor design.
Go pickup permetek ultra copper.
Rub it all over the gasket.
Then seat the gasket in grove.
Then apply a small thin bead on top of the gasket.
Mount it.... Thumb tighten all three bolts.....hard as you can.
Like 10lbs. /ft.
Then allow about 20 min to an hour to cure a bit, depending n temperature.
Then torque to spec.
Don't start car for at least full cure time.
Will never leak again.
DN
      11-29-2015, 06:30 PM   #6
slenser
9
I wish I would have gotten on here to see your post before starting. I guess I'll do that next time.
So I got into it a bit and realized that I don't have a drop of oil coming from the valve cover. So BMW lied to me...great.
I switched into OFH gasket mode.
I can't install the upper radiator hose now. The o-ring is so stretched out that it won't fit inside properly anymore. Of course I can't find a suitable one from any of the parts stores. I found one the same thickness, but too big diameter. I found one the right diameter, but too thin. I tried to use two of them, but it sprayed coolant out when I started it up.
Any idea if I can get the o-ring from BMW or do I have to buy the entire radiator hose?
