11-22-2015, 06:43 PM | #1 |
1985
Rep 6,916
DD - Porsche Cayman GT4 gets wrapped with Xpel Ultimate Paint Protection Film
This is a car that we have been waiting to do for a little while now. We were lucky enough to get two in at the same time. What an amazing sight to see two in the shop. We attacked the Guards Red one first.
What a beauty. Customer requested the dealer not touched the car, so we were lucky enough to receive a car with minimal paint issues. Lately we have been getting asked if we prep the car prior to clear filming, the answer would be yes. We typically will go thru a new car prep with each car that comes in for clear film. We remove all the factory packaging and make sure to remove all the left over adhesive and plastics off the car. After that is done we will decon the car with a fall out remover. Once that is done we will wash the car, which would include all door jambs, wheel wells, wheels, and tires will all get cleaned. Window stickers will be removed as well as any other decal or sticker. After all this is done if compounding or polishing is required we would move into this phase before the clear film goes on. Here is a list of products used: 1Z einszett Cockpit Leather Master Strong Cleaner Leather Master Barrier Sonax Alcantara/Upholstery Cleaner Leather Master Nubuck Protectant Nanolex Glass Cleaner 1Z einszett Gummi Pflege Stift Rubber Care Stick Metro Jumbo Vac n Blow Uber Leather and Carpet Brush Uber Microfiber Towels Uber Microfiber Applicator Pad Products used on the exterior: Adam's New Car Wash Adam's In and Out Spray Adam's Undercarriage Spray Adam's Detail Spray for clay lubricant Uber Clay Bar Sonax Fall Out Remover Sonax Wheel Cleaner Plus Auto Finesse Oblitarate NanoSkin AutoScrub Mitt Nanolex Tire and Rubber Restorer Uber Tire Applicator Pad Sonax EX0406 Kenotek Showroom Shine Tools used Kranzle K2017T Electric Pressure Washer Uber Foam Cannon made by MTM Uber Microfiber Towels Rupes BigFoot LHR75ES Randon Orbital Polisher Rupes BigFoot LHR 21ES Random Orbital Polisher Various Buffing Pads ScanGrip Multimatch Light 2 Grit Guard Buckets with Caddies Adam's Firehose Nozzle Metro Air Force Blaster Before shots - here we show the left over stickers, tape, dirt on the car Some polishing was required - bird dropping or light water spots Sanding marks from the factory Brake dust from the drive over to our shop Adhesive on the wheels Prep - wheels/tires/wheel wells Sonax Wheel Cleaner Plus used on the wheels, the tires get sprayed down with 1Z einszett W99 - APC Wheels get rinsed down Grills getting a quick brushing Foam bath - Adam's Car Wash Shampoo After the decon/fallout removal process we moved on to claying the car to ensure all debris is off the paint prior to wrapping it. Final rinse and blow drying the car down with the Metro Air Force Blaster After the spot polishing and another rinse down we moved to installing the Xpel Ultimate Paint Protection Film Random shots Final shots Interior shots Exterior shots Hope you enjoyed this one as much as we did. Email me if you have any questions or would like to book your car for any of the above services. Phil@DetailersDomain.com |
