F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > connecteddrive, BMW APPS and radio frequancy help
GetBMWParts
      11-22-2015, 07:08 AM   #1
sh2laba
Drives: 328i 2012
hello ,
will really appreciate any support for below options coding
- I have 6NL on my 328i 2012 and I need to activate bmw apps , connecteddrive and voice control
also (6AA,6AB,615) are in the specs , Combox is installed in the trunk ,
if its only coding required (VO) or hardware to be fitted ?
note : when FDL coding I can see the HU-ENTRY with grey CAFD ( no green CAFD to be coded ) , so is that also an issue ?
radio frequency coding :
since my car is American specs imported to Dubai -UAE , I would like to change the radio frequency
specs are :
8SC COUNTRY SPEC. RELEASE OF TELESERVICE
697 AREA-CODE 1
645 RADIO CONTROL US
876 RADIO FREQUENCY 315 MHZ
local BMW specs are
822 gulf version
698 AREA CODE 2
so which of them to be removed and what to add in order to change the FM radio frequency to European frequency
thanks in advance
      11-22-2015, 04:04 PM   #2
kitster
United Kingdom
541
Drives: G31 M Sport
Can't help you with regional coding but you need the pronav that has FSC codes for apps (6NR), it's not possible with the HU_ENTRY.
      11-27-2015, 06:10 AM   #3
sh2laba
Drives: 328i 2012
Thanks for the answer
The other thing that i cannot code any thing in the entry head unit when reading ecu and svt , all cafd under entry hu is inactive ( grey color ) so nothing in green to read the coding data and edit fdl
Any help with that
f30post
