11-19-2015, 03:24 PM | #1 |
24
Rep 167
Preparing to install jb4
So I just received my jb4 last night and now preparing/educating myself for install. Now that I have jb4 in hand, it seems like a pretty straight forward install. I do have just a few questions.
I understand I first disconnect negative battery terminal. Following, I'll be disconnecting/connecting Tmap & Map sensors. Flex fuel sensor, I leave disconnected unless I start to run e85 mixtures correct? Now this leaves me with only 2 CANbus wires to connect. I have a 2014 335 and under my dash (drivers side) I have what looks like OBDII connector ( I may be totally wrong.) Am I tapping jb4 wires into this existing connector? Or do I need to buy the $15 OBDII connector from BMS and use that? As for "software updates" is this something I'll be needing to do as well before I install? I'll be purchasing bluetooth kit from BMS so I can control everything from my iphone. If Im missing anything else or have any tips before getting started, please feel free to comment too. Thanks! |
11-19-2015, 06:07 PM | #2 | |
Pace Car Driver
1551
Rep 3,165
11-22-2015, 06:25 PM | #3 |
122
Rep 749
Drives: 2016 528i Executive Edition
I'm reading this and am a bit confused. Is there a new way to intall the jb4? I'm reading the comment about connecting via odbii which would not leave a trace? Makes it sound like no splicing into wires is necessary which would be sweet (I got the stage 1 instead because I didn't want to splice into existing wires).
Thanks! |
11-22-2015, 08:38 PM | #4 | |
Pace Car Driver
1551
Rep 3,165
11-23-2015, 08:53 AM | #5 |
24
Rep 167
I just ordered the OBDII.
What about the oem canbus (circled in red) do i tuck that away and install the new obdII there? or leave it in place and put the new obdII where the blue diamond is? |
11-23-2015, 10:09 PM | #6 |
32
Rep 185
Drives: 2017 X3 35i X Drive M Sport
Your going to be plugging the ODB connector they sent you into that port you have circled in red. You will then fish the wires through a hole in the firewall and connect them to the 2 bare wires coming off of the JB4.
I don't have a JB4 (yet) but my understanding is that plugging it into the ODBII port allows you to change maps and other features using your steering wheel buttons. I'm new to this so I'm not sure how this differs from previous JB4 versions. Also you might want to check if there is a need for the ODBII connector if your getting the bluetooth module, I THINK they do the same thing. |
11-24-2015, 09:54 AM | #7 | |
BimmerPost Supporting Vendor
4920
Rep 115,999
Mike |
11-24-2015, 09:56 AM | #8 | ||
4920
Rep 115,999
The Blue Tooth module is something else, as it allows you to connect in with the JB Software on a Tablet as opposed to hooking up a USB cable and laptop interface. Mike |
11-24-2015, 06:50 PM | #9 |
36
Rep 374
I just ordered the JB4 now, does it now come shipped with the OBD harness or do you mean that the OBD harness is now available to purchase separately ?
2024 X5 x40i
11-24-2015, 08:26 PM | #10 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
If you do choose to go the obd connector route (and I would-I did as well) you will need the "PWG hex" or "EWG hex" updates which are easily performed once the jb4 is connected. Go to n54tech.com and the file is there you need. Newer jb4 if ordered directly from BMS may have the update already, I'd check with them.
FBO-PS1 and stuff
