BMW sound system ( IN GENERAL )
11-14-2015, 07:20 AM | #1 |
33
Rep 135
Drives: 2008 318i 6MT
Hey guys..
First off all, i was looking on forum about this topic but coudnt find it. IF somebody know, pls give me link. I was looking what BMW e90 07/08 have sound system ( SS ) , i mean what type.. I found there are: stereo SS ( stock ) ; HiFi SS ; Premium SS and in M series Harman/Kardon So guys ( i mention in my old post im buying e90 ) can you pls explain am i right about this type of SS? or gave you opinion What i need to look on a car to see what SS does have couse only i can see is saying "Mp3 interface" or "CD changer"...wtf, how can i know what he have?? lol Thanks in advance |
11-14-2015, 07:38 AM | #2 |
255
Rep 2,547
BMW best system is individual audio followed by harmon kardon logic 7 - you can tell you have this if you have a center speaker in the dash and speakers in the rear doors. the individual audio systems have radial spokes visible in the door speaker grills and often the speakers are orangish in color. the logic 7 speakers are aluminum in color.
next best is hifi, this system is indicated by tweeters in the front door sail panels, but no dash speaker and no speakers in the rear doors. worst is the stereo system, this system will not even have tweeters in the front doors.
11-14-2015, 08:21 AM | #3 |
33
Rep 135
ahaaa..
So HiFi SS and Premium SS is the same thing? |
11-14-2015, 12:30 PM | #5 |
223
Rep 5,120
There are 4 systems
Base: No amp, no tweeters, no center speaker Hifi: 6 channel amp and front tweeters but no center channel. (Easiest to upgrade) Logic 7: 9 Channel amp. Has front tweeters, rear door speakers, and a center speaker. Fiber optic signal wires makes it more difficult to upgrade. individual audio: M3 premium sound system similar to logic 7 with a different amp and speakers. |
11-14-2015, 01:56 PM | #6 |
33
Rep 135
hey guys,
Thanks for replay on my post...now its more clear.... |
11-14-2015, 03:00 PM | #7 |
1918
Rep 13,117
Apparently they do different things in different
Apparently they do different things in different countrys
so I would verify things. There was one guy on here that only had one underseat speaker in your territory. We don't get the business radio or nav here in the states. (at least in the e9x) Last edited by ctuna; 11-16-2015 at 01:25 PM.. |
11-25-2015, 05:01 PM | #8 |
Rep 3
11-25-2015, 07:39 PM | #9 |
255
Rep 2,547
hifi easiest to upgrade to aftermarket amp, which is usually what is required to make aftermarket speakers sound good. just need an amp that can accept balanced inputs. popular ones include: JL audio, alpine, ARC audio etc.
11-25-2015, 07:48 PM | #10 |
Where'd my VTEC go?
481
Rep 6,067
Base audio
Option 676 - Hi-Fi Option 677 - pre-LCI Logic7; Option 688 - LCI harmon/kardon Option 752 - Individual High End Audio Option 676 HiFi is easiest to upgrade to aftermarket components because it uses regular speaker preamp outputs from the head unit with wiring to the amp in the trunk. The Logic7 and up systems use a fiber optic connection via the MOST bus to transport audio from the head unit to the amp, so upgrading to an aftermarket amp requires more work and wiring.
