bleeding coolant
11-09-2015, 05:55 PM | #1 |
111
Rep 716
bleeding coolant
when i collect my car from my mechanic after a coolant change. Should I bleed the coolant by doing the ignition sequence to turn on the water pump. I have told them to do this but I'm just wondering if I should do this just to make sure it's been done incase they haven't done it correctly ?
BMW 325i M sport - Custom stainless exhaust ( 335i set up ) - Piano black interior trim - Gloss black kidney grills - Ferric grey 18" MV3 alloys -
11-09-2015, 06:27 PM | #2 |
183
Rep 1,082
Couldn't hurt. But you could just keep an eye on the level and if steady then dont
It takes a big man to cry. It takes an even bigger man to laugh at him-- Jack Handey mods: blackout grill, finishing rods, badges, Blacklines. |
11-09-2015, 06:55 PM | #3 |
Is it the shoes!?
3884
Rep 5,112
If they're an independent BMW shop, or are very familiar with BMWs, then I wouldn't bother. You'll know if they bled it wrong if an overheat warning occurs.
11-09-2015, 07:04 PM | #4 |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
If you do, make sure you put a battery charger on.
11-10-2015, 12:59 PM | #5 |
319
Rep 1,023
You could also just ask how they bled the coolant; if they give the correct answer and they are a reputable shop, I would be comfortable that they did it correctly.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
11-10-2015, 01:52 PM | #6 |
17364
Rep 18,756
Once you drive it and if it doesn't over heat then the system wil have bled itself anyway; but you could check the coolant level once it's cooled off just for good measure. If you don't trust the shop to work on a BMW, then don't take it there.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
