XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 DIY (Do-It-Yourself) Discussions
      11-06-2015, 01:57 PM   #1
Papashawnsky
Drives: 2014 BMW X1 28iXDrive
Mud Flap installation
Hi,
Wondering if anyone has self installed OEM mud flaps. Was it difficult? Any drilling required?
      11-06-2015, 03:49 PM   #2
BeEmVe
Drives: '14 X1 x28i M-Sport
I did it on our M-Sport. Did not need to remove the wheels. Some drilling required. A couple of the "rivets" were a PITA.
http://e84.xbimmers.com/forums/showthread.php?t=789247
      11-08-2015, 02:54 AM   #3
blackhole
9
Drives: '15 X1 xDrive M-Sport
I managed to get the rear mud guards installed on my M-sport. The fit was very acceptable, and they were very easy to install.
But for the front, I found the fit was less than perfect, and the rivet holes did not line up as perfectly as I wanted -- so I returned them. Happy with just the rears.
      11-08-2015, 07:39 PM   #4
Papashawnsky
Thanks for the insights. I have the M Sport. I will take stab at the rear flaps, that seems to be where they're most needed anyhow.
      11-11-2015, 05:04 PM   #5
GTony
Australia
27
Drives: 2015 X3 F25 XDrive 28i M Sport
Originally Posted by Papashawnsky View Post
Hi,
I got from my Dealer and said put the Instructions with them.
If you know/have a good Dealer ask them for a Copy of the Instructions.
1 drilling required each front side.
      11-11-2015, 06:49 PM   #6
d1saster
Bulgaria
59
Drives: F15 N55 & E93 N51
I installed the front and rear splash guards on my M Sport without problems. Followed the attached instructions.
File Type: pdf installation instructions, splash guards.pdf (1.28 MB, 1510 views)
      11-12-2015, 02:56 PM   #7
themishmosh
34
Drives: BMW X1 xDrive35i
Installed front and rear on my M-sport also and found fitment to be perfectly acceptable.
      09-18-2016, 08:22 PM   #8
orca4wd
Drives: X1, Z3M
Mud Flaps
I just installed a set of mud flap on my x-line X1. Brought the mud flaps directly from the dealership. I believe it will be a better fit than after-market flaps. Rear flaps was straight-forward bolted onto the exist body holes with only need to drill one hole. Front flap was little tricky as the flap's lower rear mount hole did not align up. I found it easier to mount the lower plastic bolt in the bottom panel first before fold the flap onto the fender well to mount the rest of the holes. Front flap requires drilling two small holes. I had to crank the front wheel to one side to allow enough clearance room for the wrench on the inner screw.
Search this Thread:
Advanced Search
xbimmers
