11-02-2015, 04:41 PM | #1 |
Rep 38
Stance Wheels Question
Anyone in AU running these?
Stance SC-8: Available Sizes: 20x9 Front | 20x10.5 Rear Available Offsets: ET35 Front | ET45 Rear Available Finishes: Silver Machine | Slate Grey | Slate Grey Machine As per this thread: http://f30.bimmerpost.com/forums/sho...ght=stance+sc8 Can anyone see issues with the size/offset etc? Will I need spacers? Are these legal? Car is: 2015 428i M Sport Coupe w/ M Sport Brakes Cheers, Anthony |
11-04-2015, 01:09 AM | #5 |
Rep 38
Here are the specs: 20x9 ET35 in the front and a 20x10.5 ET45 in the rear...
Will I be able to also lower on H&R Sport or H&R Super Sport? |
11-04-2015, 05:02 PM | #6 |
808
Rep 5,530
11-08-2015, 01:39 AM | #9 |
Rep 38
11-09-2015, 04:51 AM | #10 |
331
Rep 4,021
Drives: F32 Coupé
I'm running these:
20" Stance SC-7 in Slate Grey with Nitto Invo Rubber... Fronts are 20x8.5 ET30 / 20x245x30 Rears are 20x10 ET40 / 20x275x30 They are pretty bloody flush. If you went more aggressive you would definitely have poke. Your rimsize/offsets would put the tyre is 5 mm closer and the rim 11 mm closer to suspension/brakes components on both front and rear than mine. (assuming 245/275 rubber.) Stance do custom offsets to order so can actually specify the sizes you want. I got mine from a Brisbane shop but they sourced them from Melbourne Distributor so if you're interested then hit me up and I can find out who they're Melbourne Distro is... Last edited by Harlequin; 11-09-2015 at 05:04 AM.. |
11-09-2015, 04:53 AM | #11 | |
Rep 38
Also where did you get your Stance wheels from? From the US or local dealer? |
11-09-2015, 05:36 AM | #12 | |
331
Rep 4,021
Drives: F32 Coupé
Got them from Stylish Wheels in Brisbane but they came from the Stance Distributor in Melbourne. I was able to specify the offsets I wanted when I ordered - they then cut them to order and I got them later that week. I'm running H&R Sport on M Adaptive. No rubbing AT ALL. EVER. They're an absolutely perfect fitment. |
11-09-2015, 05:45 AM | #13 | |
Rep 38
Any chance you could find the Melb distributor for me? - only place I have found is Ozzy Tyres in NSW - but have heard bad things about them... |
