Still need advice :) Help me diagnose this problem please
10-31-2015, 02:11 PM | #1 |
14
Rep 208
Engine mods
VRSF catless dps Jb4 Bms intakes VRSF chargepipe w/tial bov I was out driving this morning and all of a sudden my car felt like it was having a misfire. It didn't leave me stranded, I was able to drive it fine. But it kept feeling like it was having a hiccup. It began to have a very small flutter while idling as well. No check engine light came on. I just drove the car home and parked it so as not exacerbate the issue. I have 83000 miles. I did spark plugs and coil packs around 69000. I did valve cover, ofh gasket and Walnut blast a few thousand miles ago. I don't drive my car that often and drive it like an old man when I do. I have the jb4 with USB so if logging will help I can try that. Does this sound like the hpfp, or more like an injector? I'm going to go drive it and see if I can get a cell to come on. Last edited by 3pointohhhh; 11-03-2015 at 11:11 PM.. |
10-31-2015, 02:14 PM | #2 |
Major Private First Class
449
Rep 1,327
Drives: 2010 E90 335i M Sport
Check your spark plugs to see if any of them smell like fuel and are blacked out. That will be an indicator that your injector for that cylinder is bad.
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
10-31-2015, 02:37 PM | #4 |
BimmerPost Supporting Vendor
24198
Rep 190,807
Post some logs and check if there are any codes stored
10-31-2015, 02:40 PM | #5 | |
79
Rep 540
Can be a coil failing as well. They are big piles of crap Last edited by Abax335; 10-31-2015 at 09:16 PM.. |
11-02-2015, 12:49 PM | #6 |
14
Rep 208
So I'm going out to log but I'm having issues with "Failed: com4"
I used the dash to get the code and got 29d2 which I believe is misfire cylinder 6. So now I need to figure out which component is causing it. Got everything to work. 2E35 Injection valve cylinder 6, input signal. Does that mean I have a bad injector? Last edited by 3pointohhhh; 11-02-2015 at 01:04 PM.. |
11-03-2015, 09:56 AM | #8 |
Joint Chiefs of Staff
4918
Rep 115,980
11-03-2015, 01:25 PM | #9 |
14
Rep 208
I took a quick glance yesterday. I didn't have time to remove the cowl and get to the 6th injector. I will later. But just glancing at it I could see what looked like oil on the injector, so there's a good chance my catch can line is leaking or something.
11-03-2015, 11:10 PM | #10 |
14
Rep 208
So I took the cowl off and inspected the area and I was mistaken. Must have been the shadows and the slight copper color on parts of the fuel line that made me think there was oil in the area. It is completely clean.
Do I bite the bullet and order an injector? Is there a way for me to test and make sure it's bad? Should I swap two injectors and see if the misfire moves? |
11-03-2015, 11:50 PM | #11 |
4ut0strd4
47
Rep 223
Pull the plug for cylinder 6 if the threads/tip are wet with a watery looking substance it's fuel and you need to replace that injector to remedy your issue.
11-04-2015, 01:32 AM | #12 |
14
Rep 208
Sweet. That was the info I was looking for thanks! Now is the injector just a drop in part? Why was I reading about needing programming for injectors? I can just put a new one in and call it a day right?
11-04-2015, 03:08 AM | #13 | |
57
Rep 272
N54 Injector Swap & Coding Diy! http://www.e90post.com/forums/showthread.php?t=651538
FBO , MHD , tuned
11-04-2015, 01:46 PM | #14 | |
14
Rep 208
11-04-2015, 03:13 PM | #15 | ||
57
Rep 272
FBO , MHD , tuned
11-04-2015, 04:05 PM | #16 |
14
Rep 208
Yeah this will be the first maintenance I have had to do that will require unnecessary work imo, aside from the oil filter housing gasket having the dumbest design ever, of course.
