Go Back   7Post - 7 Series Forum > BMW 7-Series Forums > (G11) 7-series General Discussions
      10-28-2015, 01:06 AM   #1
bobox6m
17
Drives: '10 X6 M; '13 Granturismo MC
New 740i spotted!!
My neighbor picked up a brand new 740i and it is absolutely beautiful. This is my first time seeing the new 7 series in real life and I can only say that it looks much more refined in the flesh. The owner also has a F01 7er [IMG][/IMG]right next to it for a direct comparison, and the G11 just outshines it from every angle.
Apologies for the mediocre pictures; took the pics with my iPhone and the garage lighting was horrible
      10-28-2015, 07:59 AM   #2
usmabmass
232
Drives: 08 550i, 23 i4 M50, 24 iX M60
I may be dumb, but I just noticed that some of the G12 headlights have an aluminum strip running across the bottom of the headlight housings - I assumed every one had this strip, but I see this one doesn't.
Does that aluminum strip only come on LED lights?? (I also thought LEDs were standard so what do I know)
      10-28-2015, 11:15 AM   #3
CaliE90
CaliE90's Avatar
353
Drives: BMW
2021 M550xi  [0.00]
The aluminum strip is for the "icon" LED headlights that are only on the 750i. 740i has standard LED headlights but doesn't have the same design as the 750i headlights.
Retired- '14 F10 535i -- 3 2 1 | '08 E90 335i -- 4 3 2 1 |
      10-28-2015, 12:03 PM   #4
nextceo
9
Drives: BMW 7 Series
I had no idea there was a different look for the headlights between the 2 models. Thanks for sharing!
      10-28-2015, 01:58 PM   #5
BIMPY3011
Suriname
104
Drives: 1 Series
this is actually the basic led light. You have adaptive LEDs and the Laser lights. The adaptive LEDs and laser lights look quite similar to each other. You can recognise the lasers with the blue line in the angel eyes.
      10-29-2015, 10:47 AM   #6
TheBry
TheBry's Avatar
Drives: 2016 G12 750i xDrive
Correct, visually they're different, however, both LED lighting packages available here in the US are "adaptive".
There's the "Adaptive LED Headlight" (standard on the 740i) which features more traditional corona rings, amber-colored turn indicators on the side.
Then there's the "Icon Adaptive LED Headlight" (optional on the 740i and standard on the 750i) which features more stylized corona rings that have depth -- and visually connect via light bar to the kidney grille. These more advanced headlights also feature a horizontally split chamber for each light (top portion is low-beam headlight and bottom portion is high-beam headlight); additionally, the amber-colored turn indicators run horizontally above the headlights).
The differences between the two are actually quite perceptible if seen side-by-side.
Past: 2008 M3 (E93) naturally aspirated V8 realness!
Past: 2012 740Li (F02) M-Sport (European Delivery)
Present: 2016 750i (G12) M-Sport
Search this Thread:
Advanced Search
7post
