PPK stage 1 to eliminate lag?
10-27-2015, 02:05 PM | #1 |
109
Rep 1,062
Seems like people used to do this back in 2012 to eliminate turbo lag, why did the stop?
Sideways is the way of life.
10-27-2015, 02:08 PM | #2 |
BimmerPost Supporting Vendor
24198
Rep 190,807
Not sure what the question is
10-27-2015, 02:09 PM | #3 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
Lol. A BEF or flash tune is 100x better than ppk 1. Close the wastegates on the jb4 if you want less lag.
Just one of those ThatRWD threads. |
10-27-2015, 02:33 PM | #4 |
109
Rep 1,062
Closing the waste gates through the jb4 made no difference on my car.
I'm not sure how I came across the ppk thread but the results are different, the vendor tunes give you more power but from what I've read the PPK did a much better job of reducing lag. Hopefully someone whose experienced both can chime in, I'll post the threads I was looking later tonight. |
10-27-2015, 10:12 PM | #5 | |
1552
Rep 3,475
And setting menu 10 to 5 (all the way closed) reduces lag for me a ton. |
10-30-2015, 10:04 AM | #8 |
109
Rep 1,062
Can you flash the PPK yourself or do you have to have the dealer do it? How does the instant low end response compare with cobb v3 and other tunes you might have tried?
10-30-2015, 10:37 AM | #9 | |
Joint Chiefs of Staff
4918
Rep 115,980
Mike |
10-30-2015, 02:30 PM | #10 | |
170
Rep 618
10-30-2015, 03:45 PM | #11 |
595
Rep 1,693
PPK's spool mode AFR target is leaner than stock and the spool mode timing is a fair bit more advanced compared to stock. I might try it one day and see how it feels.
Most OTS maps don't even have spool mode enabled so it's no surprise that PPK felt like it spooled quicker. |
10-31-2015, 02:49 PM | #12 | |
109
Rep 1,062
I'm fairly tech savvy and don't have issues modifying values and roms/flashes but by easy I mean something that can be done in an hour or two - easily without much research. Otherwise I would rather pay the dealer.
10-31-2015, 05:10 PM | #13 |
648
Rep 2,013
ppk crank numbers are shown to be 336hp, 377lb ft. Must be that high lo end torque that rids of lag. I want to do it, still the most reliable compared to others but why freakin so expensive...
335i e92 TPC 19Ts
10-31-2015, 06:02 PM | #14 |
469
Rep 1,536
Surely you can just flash a PPK bin on your car using MHD? Shouldn't have to visit the dealer for anything.
10-31-2015, 06:23 PM | #15 |
109
Rep 1,062
Or even WinKFP or the same method as the alpina B3 flash. Or screw it, I would like to modify one of the tunes to get instant low end response instead.
10-31-2015, 06:34 PM | #16 | ||
Nomore
149
Rep 793
This could be flashed pretty easily using my MHD as a custom map. All it does is bring up menu where you select a file off your android downloads folder or SD card. Etc... |
10-31-2015, 06:41 PM | #17 |
648
Rep 2,013
Yes, if one can get hold of a ppk bin. Would be great if mhd can offer that as a stage. Makes sense from a marketing perspective as well.
335i e92 TPC 19Ts
10-31-2015, 06:50 PM | #18 | |
469
Rep 1,536
It's for IJE0S. Which I think is the only ROM to get the PPK (not 100% on that). If you are on IJE0S you could give it a go. |
11-01-2015, 08:25 AM | #20 | |
648
Rep 2,013
http://www.shopbmwusa.com/PERFORMANC...ORMANCE/TUNING
335i e92 TPC 19Ts
11-01-2015, 09:06 AM | #21 | |
109
Rep 1,062
I'd really like to get this figured out, PPK almost eliminates turbo lag and from what I've seen the throttle response is instantaneous. And combined with an alpina B3 flash the shifts are faster than a Alpina B3 flash without PPK.
11-01-2015, 09:12 AM | #22 |
648
Rep 2,013
Find a deal, let me know. Would be fine w 600. Best i could do is 800-900 w install. Im quite sure sw only, i8a0s is fine, does need the 840 option tho.
335i e92 TPC 19Ts
