Quick shout-out to SPXXX!
10-26-2015, 10:36 PM | #1 |
75
Rep 731
Drives: 2008 335i 6MT
Just wanted to post a write up about spxxx. I initially reached out to him to get a custom tune for a friends car.. He was extremely helpful and even offered free ethanol base tunes. Since then he has helped dial in that car, my car, and now onto another friends car. If anyone has any tuning questions or needs any help dialing in a tune.. go to him!! He is quick to respond to e-mails with little hassle. My car was running the best it ever has on one of his tunes.. Can't wait until my clutch is installed to drive the car again!
Just wanted to share that I am extremely satisfied Will get the car on a dyno asap and post some dyno charts of my FBO 08 335i 6MT with his e35-40 tune.
2008 335i Coupe / Alpine White / 6MT / Fully Built Motiv Closed-Deck Motor / Motiv ST Kit / XR 105/69S / Motiv Twin Disc / VRSF 7.5 FMIC / ActiveAutowerke Exhaust / EOS Intake Manifold w/ 1050cc injectors / TiaL BOV / External VTA PCV / Quaife LSD / DSS Axles / KW V3Coilovers
10-27-2015, 07:29 PM | #3 |
42
Rep 380
11-16-2015, 01:44 PM | #4 | |
Bob Saget
355
Rep 2,229
I thought the only standalones were cobb and MHD?
In memory of Robert E. Flynn (AR)
11-16-2015, 03:17 PM | #7 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
11-16-2015, 03:18 PM | #8 | |
75
Rep 731
This is with a small boost leak. Updated today and boost is back to 21.3 in 4-6th Will post another log asap!
11-16-2015, 05:23 PM | #9 | |
469
Rep 1,536
11-16-2015, 05:25 PM | #10 | ||
75
Rep 731
EDIT: also that run is with only DTC.. When DSC is fully off it spins so i keep it on DTC to get better traction
11-16-2015, 07:39 PM | #11 |
220
Rep 695
1. You need to have DSC completely disabled when logging.
2. Begin the log in 3rd at 2k RPM 3. You should be able to see evidence of wheelspin or clutch slip by looking at your RPM data. |
11-16-2015, 08:16 PM | #12 |
42
Rep 380
How does your tuner not see throttle closures? It's sometimes caused by torque limiter kicking in.
Cam only...
11-16-2015, 08:55 PM | #13 | |
BimmerPost Supporting Vendor
1334
Rep 1,701
Drives: Slot Machines.. Keep Taking $
I'm sure this wasn't by design as your boost is also above target, which leads me to agree with CarAbuser. My assumption is if load is increased, the throttle closure would subside even though your map is still exceeding boost target due to throttle mapping changes which were common with COBB & JB4 maps. I have stopped using this because it causes low load oscillation and throttle plate bouncing which is noticeable if you know what you're looking for. Not saying that all of my tunes are perfect, but my new v6 MHD maps will be geared more toward boost targeting and using load to shape the power curve. (load by gear) Throttle closures will happen, but shouldn't be drastic like this or noticeable, just enough to keep power consistent and smooth. (Minimize wheel spin, Maximize performance) |
11-16-2015, 10:30 PM | #14 |
Boost
1354
Rep 3,692
Drives: 135i M-Sport
Yep, we moved from a lower E85 blend to higher E85 map and load targets didn't get updated from the previous map when we changed the WGDC mapping which is the cause of the throttle closures. Still a work in progress.
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
