JB4 keeps switching to map 4
10-26-2015, 10:56 AM | #1 |
64
Rep 421
Hey guys, so I have been running jb4 map 7 with an bms e85 backend flash tune and has been running strong. I just got the mmp inlets installed and now it keeps switching to map 4 as soon as the max psi hits. Could it be that the increased airflow from the inlets are causing this problem? my fail safe psi is set at 21 psi which is the most i could get the jb4 to set it. As soon as it hits that it switches to map 4 which is understandable. But I have tried using map 2 as well, and its hitting 17-18psi and then it switches to map 4 again. Do i just need to get a custom flash tune as the mmp inlets are creating way too much airflow for the jb4 to handle? Any ideas? below is the list of mods i have.
mmp inlets vrsf 7" fmic ets chargepipe/synapse bov n54tuning catless DP AE exhaust fuel it stage 2 LPFP Mfactory LSD JB4 BMS e85 back end flash tune I put in about 10 gallons of e85 and top off with 93.
07 335i e92
10-26-2015, 10:58 AM | #2 |
3441
Rep 79,211
Get a datalog, it's really the only way for us to know.
Could be fuel related, boost, load, who knows. You likely need some adjustments in your tune when going to aftermarket inlets. |
10-26-2015, 01:53 PM | #4 |
64
Rep 421
Thanks for the responses. I will datalog it when i get a chance. Been so hard to mess with it with my work schedule.
It is set at 21psi
07 335i e92
10-26-2015, 02:58 PM | #5 |
184
Rep 1,702
Drives: Audi TTRS, 335is
You should get an SES flash with it too.
One flash - over boost. Two flashes - Lean over 14:1 for >1 sec over 4500rpm Three flashes - HPFP dropping below 7 Log it of course but the SES and amount of times it flashes should give you a quick indication of what the culprit is. |
10-26-2015, 03:01 PM | #7 | |
73
Rep 350
Then you can figure out why u hit failsafe. Also you can help test this new feature |
10-26-2015, 03:06 PM | #8 |
64
Rep 421
ces/ses does not come on. it just goes straight to map 4 without any indication. I only notice it when i wot and shift to the next gear, it only goes to 8psi so i check the map settings and it will be on map 4.
07 335i e92
10-26-2015, 03:06 PM | #9 |
64
Rep 421
which forums is this you speak of?
07 335i e92
10-26-2015, 03:52 PM | #10 | |
BimmerPost Supporting Vendor
24198
Rep 190,807
Read the codes, and post a datalog once you have a chance. Trying to figure it out without any data is more of a guessing game than anything else
10-26-2015, 04:44 PM | #13 |
24198
Rep 190,807
Sounds good
