Boost Solenoid Failing Prematurely?
10-23-2015, 01:36 PM | #1 |
530
Rep 2,083
A few months ago I had this very loud tapping sound at idle happen to me and was told it was a boost solenoid (they had about 88k miles on them). While it was tapping I lightly hit each boost solenoid with a screwdriver, and one hit to the front solenoid and the tapping instantly stopped.
So I replaced both solenoids with Pierburg solenoids from ECS Tuning. The tapping went away for a few months but came back this week about 1000 miles later. Again, while it was tapping, I lightly smacked both solenoids with a screwdriver and the tapping stopped instantly once I hit the rear solenoid. Why are these failing so often? I was thinking that it could be related to setting the MHD wategate rattle setting to 0% which keeps the gates open on decel. I'm also running the E40 map which target 21+ psi. Perhaps these settings are stressing the solenoids too much? ECS is sending me a replacement since they are still under warranty. Here is a video of the tapping, tapping starts at 29s:
2013 135is DCT Carbon Black Metallic |
10-23-2015, 06:59 PM | #2 |
648
Rep 2,013
Not sure if your solenoids failed. Have you checked their opeartion with a vacuum gage, say at idle? Also, i dont think they see any boost so 21 psi shouldnt matter. Their only purpose is to open or close the wg with vacuum.
335i e92 TPC 19Ts
10-24-2015, 09:51 PM | #4 |
530
Rep 2,083
Yes all lines were replaced about 5k ago and the reservoirs are fine. It's definitely the boost solenoid.
Just curious why it failed so quickly. Could be coincidence I guess. I'll replace it and see how long it lasts but I'm wondering if it's getting stressed too much (exceeding duty cycle for example) by forcing the wastegates full open the majority of the time. |
10-25-2015, 12:00 PM | #5 |
MR. Rocket
46
Rep 398
Drives: 2010 E92 335i M-Sport
I get the same kind of noise periodically as well. Were you having any symptoms of boost leak?Have you noticed any performance difference with replacing boost solenoids? Also running Wedge E40 tune.
10-25-2015, 03:41 PM | #6 |
530
Rep 2,083
No noticeable difference after replacing the solenoids, just no tapping sound. No boost leaks, I checked.
12-16-2015, 05:44 PM | #7 | |
Major Private First Class
449
Rep 1,327
Drives: 2010 E90 335i M Sport
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
12-16-2015, 06:33 PM | #8 | |
530
Rep 2,083
I have not replaced the possibly-faulty solenoid since creating this thread. The tapping sound has not come back. I should replace it though before the warranty on the part expires.
