Bone stock on stage 1 sport? On cobb v3
10-23-2015, 12:49 AM | #1 |
72
Rep 385
Quick question got 2008 335i all stock live in CA tuning with Cobb v3. I should be running ST stage 1 sport right? I know I cant run the aggressive since CA have 91 octane only. Will be installing vrsf 5" step fmic soon and that will be stage 1 +fmic I believe. By the way i bought the cobb v3 used it came with everything except the booklet or manuel but searched on here for the install info.
10-23-2015, 01:18 AM | #2 |
72
Rep 385
Did more reading i think 91 octane is for stage 1 sport but since im in CA ACN 91 octane i need to be stage 1 drive instead of sport. Correct me if i am wrong guys. Thanks. Car seems to run fine on sport from the test drive but i wants whats most reliable and best for the car.
10-23-2015, 07:12 AM | #3 |
17
Rep 627
You should be fine running stage 1 sport, seems like plenty of people in cali are running it successfully on 91. Watch your engine temps and do some logs to make sure everything is in check.
10-23-2015, 08:21 AM | #4 |
72
Rep 385
Yeah im new to bmw and cobb so gotta still learn more. I will keep my eyes on it.
10-23-2015, 09:48 AM | #5 |
3441
Rep 79,211
You can see how your car is accepting the map by running a datalog of both and take a look. Post to datazap.me if you don't know what you're looking at.
3rd gear run, wide open throttle from 2500 RPM to 6000 RPM. If you can shift into 4th even better. |
10-23-2015, 10:38 AM | #6 | |
Joint Chiefs of Staff
4918
Rep 115,980
Logging is always the answer as each car is different and it depends on quality of gas, ambient temp, state of tune of the car, etc. Mike |
10-23-2015, 10:41 AM | #7 | |
72
Rep 385
10-23-2015, 10:57 AM | #8 |
35
Rep 169
AZ has the same ACN91 craptane. I ran sport for a long time, it is perfectly fine. You should really have someone do an etune for you though. That is the best way to know for sure.
IG @pobudz | '08 e92 335i - MOTIV 750 w/ PI & AEMMHD tuned, tial bov, ER cp, ADE "800HP" fmic, Corsa 3.5" catback, m3 suspension bits (F&R sway, F&R control arms), rogue toe arms, MOTIV motor mounts, UUC trans mounts and RTD shifter. H&R sports and Koni's, 17x9/17x10.5 Forgestar F14 w/ Mickeys. Quaife 3.08 LSD, M3 subframe and diff bushings. MOTIV Twin disk. Fuel-IT Stage 3+.
10-23-2015, 02:55 PM | #9 |
BimmerPost Supporting Vendor
24199
Rep 190,807
I ran aggressive on 91 for a while without any problems, so you should be fine. That being said i strongly recommend logging
10-24-2015, 03:06 AM | #10 | |
261
Rep 1,029
"The likelihood of one individual being right increases in direct proportion to the intensity with which others attempt to prove him wrong."
2015 F82 M4 - Sakhir Orange Metallic 2013 E92 M3 / 2013 E92 335is / 2010 E90 335i / 2007 E90 335i |
10-24-2015, 05:10 PM | #11 |
72
Rep 385
Thanks
