10-20-2015, 03:40 PM | #1 |
102
Rep 228
Low beam shining too high!
Has anyone had any problems with the low beam shining to high and dazzling every oncoming vehicle?
I was out for a little drive tonight after getting the Birds suspension put onto my car and just about every single oncoming car flashed me as if I had the main beams on, even cars in front were putting there hazards on because they were getting dazzled, I thought the lights were self levelling, I can't find any manual way to adjust them down, now this has just started since the new suspension has been fitted, any ideas?? |
10-20-2015, 03:49 PM | #2 |
922
Rep 2,559
Pop bonnet & adjusters are within front slam panel. Iirc, they are the inside ones of the 2 each side. Use an Allen key to turn them down. (line up on a wall / garage door to see them move up/down)
Garage should have adjusted them when fitting the suspension as iirc, same happens when the ACS springs are fitted |
10-20-2015, 03:52 PM | #3 |
652
Rep 3,445
Drives: G22 M440D
There is a section in the illustrated ACS fitting instructions about re-calibrating the arm that connects to your suspension (and used to detect ride height changes). Don't have it to hand but you can find it online.
Guessing when you had your suspension fitted today they haven't done that yet - your lights will be off. Do not try and adjust the headlamps themselves .... ! D. EDIT : Look here : http://preisliste.ac-schnitzer.de/ac...3130232310.pdf
Escort Mk1 RS2000 (2.1 2x44IDFS, BVH, Kent FR32, 5spd, 180 BHP) : M440D ¦ Previously : F32 435D : F32 430D M Sport sDrive, 335D E92 2006
10-20-2015, 04:09 PM | #4 |
8571
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
Yes, it will be that your system needs re-calibrated or worse, that the technician damaged or forgot to re-connect the rod that tells the car the relative ride height front to back.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
10-20-2015, 04:13 PM | #5 |
6431
Rep 8,504
Bird's realigned my headlights when they installed the springs and ARBs - an essential part of the job !
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
