335is BMW PE
10-20-2015, 03:27 PM | #1 |
39
Rep 249
335is BMW PE
I have a 335is which I'm sure comes equipped with the BMW PE exhaust, but I want it to be louder but still keep the sound.
Can I achieve that with a muffler/secondary cat delete? Any tips? I don't want to have rasp, but I wish to have a louder exhaust at lower rpms as well. |
10-20-2015, 03:31 PM | #2 |
252
Rep 998
The 335is doesn't come equipped with the performance exhaust in stock form. If you want more noise without rasp, I would suggest getting catless Downpipes. If that's still not loud enough, do the secondary cat deletes.
10-20-2015, 03:32 PM | #3 | |
Joint Chiefs of Staff
4918
Rep 115,980
Mike |
10-20-2015, 03:38 PM | #4 | |
255
Rep 554
Drives: 2013 335is E93 6MT
That can ostensibly be cured with a pair of resonators, which are currently headed my way.
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings |
10-20-2015, 03:47 PM | #5 |
252
Rep 998
I ran catless dp's with the PE and personally didn't think it was too bad. But yeah, putting in some resonators in place of the secondary cats would probably help a lot with drone.
10-20-2015, 04:00 PM | #6 | |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
I always hear catless on our is exhaust sucks, but with PE it seems to sound nice for everyone...though I like the is exhaust > PE. OP do the golf tee mod..just unplug actuator. I decided to go with catted dp and hoping that will keep the rice out...will be posting when installed.
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
10-20-2015, 04:16 PM | #7 |
96
Rep 448
You're in CA, so I would personally just add the BMW PE since downpipes can be a pain to pass emissions with. I haven't personally dealt with this, but some on here have had issues with smog and the dp fix. Don't unplug the actuator, I did this for a while and it does indeed sound better, but there is drone present on the freeway which was rather annoying. The BMW PE has no drone and only a little rasp in my personal opinion, and it will get people's attention if you drive it hard.
10-20-2015, 05:03 PM | #8 |
102
Rep 1,903
Drives: e92 335i 6MT
You can do the PE exhaust mod to it and let us know what's inside the is muffler
10-20-2015, 06:01 PM | #9 | |
39
Rep 249
10-20-2015, 07:10 PM | #10 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
Vibrant 1792's seem to be the go to resonators. I might go this route myself. Waiting on JasW to get his on and get a opinion.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
10-20-2015, 07:59 PM | #11 |
255
Rep 554
I actually ordered the Vibrant 1790s. (Should be here tomorrow, though I won't be able to get to the exhaust shop until next week.) People have gone with either -- I opted for the 1790s because at 2.25" they're supposed to be the same size as the stock piping, while the 1792s are 2.5". Then someone today said on another thread here that the stock piping is really 2.36", or 3mm larger than the 1790s. Whatever. I'm sure either would be fine. I just want to lose the rasp, which if you're driving a vert, is impossible to ignore, as it is when the top is up and the windows are closed. Gurgling, popping, and loud, low grumbling are great, but that metallic buzz saw farting -- with an almost trumpet-like effect when you engage the clutch on the MT at the top of the rev -- is embarassing on such an otherwise classy car. Cold start is over the top, too.
The key issue seems to be placement, and whether to swap out your secondary cats or have them artfully positioned elsewhere, either just after the x-pipe or before somewhere in the mid-pipe. I'll find out next week.
10-20-2015, 08:46 PM | #12 | |
39
Rep 249
10-21-2015, 04:00 AM | #13 |
1549
Rep 3,788
This is what I have learned:
The IS exhaust stock without DPs sounds great with or without golf tee mod. The IS exhaust with DPs sounds horrible past 4k rpms, super raspy. The Performance exhaust without DPs sounds too quiet and I would not recommend this on a IS, better to stick with stock exhaust if no DPs. The Performance exhaust with DPs sounds like PURE SEX! This is what I am currently running. I've also tried the AE Dual tip catback exhaust on the IS and although it was not bad, I still didn't like it. |
10-21-2015, 05:40 AM | #14 | |
255
Rep 554
Note the guy in the post below that one (which also has sound clips) just swapped out the secondary cats on his E92 Xdrive for the Vibrant 1790s. That actually sounds pretty good. Of course, neither of these have the 335is exhaust, so I have no idea whether the exhaust will sound like that with the resonators. If I had to do it all over again, I might have just gotten the ar design catless DPs with the built in resonators, but they are almost $500 more. EDIT: I just realized you're in Cali -- you might want to just get the c-PE high-flow catted DPs. You'll get no rasp, you'll pass emissions, and you only lose about 5hp vs. the catless (i.e., you'll gain 5hp less than you otherwise would with the catless). Here's a mini-review of the c-PE catted DPs on the 335is.
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings Last edited by JasW; 10-21-2015 at 05:49 AM.. |
10-21-2015, 02:25 PM | #15 | |
39
Rep 249
Emissions aren't a problem |
10-21-2015, 03:25 PM | #16 | |
BimmerPost Supporting Vendor
24198
Rep 190,805
