Testing pcv system out
10-20-2015, 05:19 AM | #1 |
39
Rep 364
Hi guys, as a test if you remove the line from the pcv going to the air intake and feed it into a glass jar could you perhaps diagnose if the pcv is expelling large amounts of oil into the intake due to something going bad in the pcv system? Is there a better way to test it?
10-20-2015, 07:33 PM | #3 | |
57
Rep 272
FBO , MHD , tuned
10-20-2015, 07:35 PM | #4 |
654
Rep 946
There aren't many parts that can go wrong in the pcv system. The valve is cheap and fairly easy to replace and I believe one of the lines has a check valve. There are passages in the valve cover that can clog but they don't often cause problems.
10-20-2015, 07:45 PM | #5 |
39
Rep 364
Long story short im having bad smoke on deceleration. I had the valve cover and the pcv replaced yesterday to no avail. When I asked the mechanic if they tested the internal pcv components they seemed very hesitant with my questions which leads me to believe they checked nothing inside the valve cover. Before I go to the next step and replace turbos, valve seals ect I want to make sure 100% im not getting excessive blow into the intake on deceleration.
10-20-2015, 10:02 PM | #6 | |
Maximus Decimus Meridius
1130
Rep 4,584
F30 335i Melbourne Red Metallic M-Sport Package |
10-20-2015, 10:22 PM | #8 |
654
Rep 946
10-21-2015, 12:28 AM | #9 | |
93
Rep 606
10-21-2015, 08:13 AM | #12 |
2341
Rep 3,539
The check valve hose or pcv hose is accessible from the top rear after removing the engine cover (no need to remove the valve cover).
Careful no to break the tabs that hold the hose clipped in. Once removed, start to flip the hose up/down and you should hear the valve flapping inside. I was told by the dealership that my pcv valve and hose was blocked and needed to be replaced. So I ended up ordering the Rob Beck metal pcv valve and bought the oem hose. After removing the pcv valve it seemed a bit sluggish, but I thoroughly sprayed brake cleaner into it and it was flapping around like new (at this point the valve had some damage from the pliers I used to remove it so I didn't bother putting it back on). I did the same with the pcv hose although mine seemed fine. I ended up taking an x-ray image of the pcv valve to see what's going on in there. Not much to it really. If you can manage to remove the valve without damaging it, you could potentially clean it up with brake cleaner and put it back on. Cheers |
10-21-2015, 08:30 AM | #13 |
380
Rep 1,497
Our cars have 2 check valves. One is that plastic tube and the other is the actual pcv that's underneath the fuel line that needs to be unscrewed. If your mechanic did replace the valve cover, and did use rtv around the edges, make sure that it didn't seal or cover the ports on the head that need to be left open for the engine to breath.
I did a friend's valve cover after he took it to a shop for smoking and when he brought it to me I found the ports blocked off due to using to much rtv. Now he is smoke free |
10-21-2015, 08:30 AM | #14 |
25
Rep 197
At the end of my check valve, there is a tiny filter (previous owner's doing). When I pulled it off, it was extremely oily. Like, the inside was black with oil.
I'm also getting smoke on deceleration and bad oil smell. Bad PCV system for me? |
10-21-2015, 07:37 PM | #15 | |
39
Rep 364
10-22-2015, 11:24 PM | #16 | |
73
Rep 350
I think u can also pull out the vacuum hose from the vac canister. That should reduce your boost to zero. See if it smokes. Just remember what hose goes to what canister. |
