please look at my logs Why is my car so laggy
10-20-2015, 05:07 AM | #1 |
163
Rep 466
I am new to bmw's but new to cars. I have a 620whp s2000 and i do and always do all the work on all my own cars.
I bought a bone stock 2007 335i with 92,000 miles about 2 months ago. I changed all the plugs and coils and did a walnut blasting on it. I installed a jb4, vrsf down pipes, charge pipe and 7 inch intercooler as well as a tial bov. i just realized my car is very laggy. I run 20-30%e85 and i dont hit 10 psi will about 3500rpm and 15psi at about 4000rpm. The car is fast but spools very slow. are my turbos busted. Even when stock the power band felt the same just with a lot less top end power. I just learned how to log and here is my first log. I set the default wastgate position on the jb4 at 1.5 any higher they will rattle like crazy. Bone stock the car did not rattle. I highly doubt there are any boost leaks. even if i set the DWP at max i dont feel like the lag is much better.
2007 e90 335i
pure stage 2 DD turbos, rb inlets Last edited by Riceball777; 10-20-2015 at 01:27 PM.. |
10-20-2015, 07:20 AM | #2 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
Need the .csv file. Are there any codes?
10-20-2015, 01:33 PM | #6 | |
163
Rep 466
is the PWM the wastegate duty cycle? It reads 100 from 1200 rpm to 3000rpm and i'm getiing almost no boost. Like i said i'm 90% sure there is no boost leak because when the car was stock it felt the same way except for a lot less top end power. And i just upgraded the intercooler and the charge pipe so i'm sure i tightened all of the couplers. I'm guessing vacuum leak, bad boost solenoids or bad turbos? but is it possible the turbos are bad even though i hit 15 psi at about 4,200 and the car feels fast.
2007 e90 335i
pure stage 2 DD turbos, rb inlets Last edited by Riceball777; 10-20-2015 at 01:39 PM.. |
10-20-2015, 05:39 PM | #8 | |
35
Rep 169
http://datazap.me
IG @pobudz | '08 e92 335i - MOTIV 750 w/ PI & AEMMHD tuned, tial bov, ER cp, ADE "800HP" fmic, Corsa 3.5" catback, m3 suspension bits (F&R sway, F&R control arms), rogue toe arms, MOTIV motor mounts, UUC trans mounts and RTD shifter. H&R sports and Koni's, 17x9/17x10.5 Forgestar F14 w/ Mickeys. Quaife 3.08 LSD, M3 subframe and diff bushings. MOTIV Twin disk. Fuel-IT Stage 3+.
