10-19-2015, 07:10 PM | #1 |
Mr Bill
296
Rep 545
Suspension Research
Ok, so here is what Im looking for. As close to stock M Sport ride as possible with the car about 1 lower. Ideally I would be able to adjust the height. A bit stiffer is fine (M3 stiffness), but not much more than that. Prefer not to spend <2000, and will probably buy used. I will install myself. This is what I have found so far with my research. Anyone care to comment?
H&R Sport / Eibach springs Best I can tell most dont like this combination. I think the shocks are a bit too long and they bottom out, along with not having enough damping for the 30% stiffer springs. Probably worse on the H&R super sport springs. Some have added Bilstein B8 shocks, which seems to help, but then you are into it for about $1000. There have also been several instances of the top hats coming apart with this system, so beware although BMW is coming out with a stronger top hat. Dinan Springs Better ride quality, but fairly expensive. Includes new bumpstops which I suspect are progressive and get rid of some of the immediate bottoming issues above. Coilovers KW V1 Not rebuildable A lot of issues with the shocks making noises which usually means the internal cartridge (gas/oil) has come apart. You need to send them back to KW when this happens at $130 / each. Generally considered good ride quality though. KW V2 Rebuildable, still twin tube design, adjustable. No issues that I know of. (I had a set on a racecar and they were pretty nice) Bilstein B14 rebuildable, Non adjustable montube design. Progressive springs, but reports they are pretty stiff? Quality design though. -30 50 mm drop Bilstein B16 rebuildable, Adjustable montube design. Progressive springs, but reports they are pretty stiff, but maybe not as stiff as the B14 on low settings? Quality design though. -30 to -50 drop TC Kline Single and Double adjustable Basically Konis with special valving. I had these on an M3 and they rode great (single adj). Were not that great at the track, but good daily driver car. BC BR Coilovers Not too much information besides the sticky? Anyone? CKS Coilovers Not too much information besides the sticky? Anyone? |
10-21-2015, 06:42 AM | #3 |
3489
Rep 9,709
I'll throw my option in there....Bilstein PSS10 KOMFORT. These are like the regular PSS10 but with slightly longer springs. Drop is 10-30mm rather than 30-50.
On damper setting 0 they are as comfortable as a stock M Sport, stiffer but less crashy. On setting 10 they are awesome on track, car feels like a go-kart. |
10-21-2015, 06:12 PM | #5 |
925
Rep 3,089
Personally, I think if you don't track your car the KW V1 is all you need. Unless you have a very particular ride you are looking for paying more for the adjustability would be a waste.
10-22-2015, 04:26 AM | #6 |
3489
Rep 9,709
10-22-2015, 04:35 AM | #7 |
3489
Rep 9,709
I disagree, as the cost to change suspension is quite high (the labour / wheel alignment, etc) the relatively small cost between for example KW V1 and KW V2 makes it an easy decision to go for the adjustability of the V2. Sure you will get used to the ride on the V1, but you will never know whether 2 clicks would have made the world of difference for you.
