TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Microfilter service
      02-22-2008, 03:53 PM   #1
roofer
roofer's Avatar
United Kingdom
21
Drives: 335D M Saloon
Microfilter service
Anyone had one yet?
They want the car for the day Tempted to just do it myself.
      02-22-2008, 04:14 PM   #2
Z4 Beemer
Z4 Beemer's Avatar
Scotland
83
Drives: 2009 Z4 sDrive 23i
2006 E92  [0.00]
2004 Z4 2.2i  [8.00]
Is this the same as the pollen filter?
When I got the Z4 serviced they initially didn't have the filter in stock. They asked me to take it back in, and it took about 10 mins to fit... I just waited for it. I think it was located somewhere down at the passenger footwell area.
E89 Z4 sDrive 23i... for the more discerning driver
      02-22-2008, 04:16 PM   #3
Serjames
Serjames's Avatar
United Kingdom
128
Drives: E93 335i M-sport
if it's the filter that filters cabin air, that takes like 2 minutes to change. Only 6 8mm fasteners to remove
SJ
      02-22-2008, 04:52 PM   #4
quattrogmbh
23
Drives: BMW
Easy to do yourself and then just reset the service alert via the stalk.
      02-22-2008, 05:45 PM   #5
roofer
roofer's Avatar
United Kingdom
21
Thats what i'll do
      02-22-2008, 06:08 PM   #6
ShereKhan
ShereKhan's Avatar
United Kingdom
96
Drives: BMW G20 330e M Sport MY20
2020 BMW 330e  [0.00]
Mines due in 3k.
stealer told me its 30 mins in garage tops
20 BMW G20 330e M Sport Portimão Blue/Cognac, Driver Pro, Tech,M+ lumbar, storage packs
Long gone -15 Peugeot 308 2.0HDi GT AUTO Magnetic Blue, 10 BMW F10 520D SE Xirallic Imperial blue/Cinnamon Brown, 06 E90 320si - Le Mans Blue - Totally standard specification (Scrapped RIP 12/08/2010), 00 Peugeot 306 2.0 SE Cabriolet, 94 Rover 214 SEi, 91 Fiat Uno 60S Mk2
      02-23-2008, 04:38 AM   #7
Chris33
Chris33's Avatar
United Kingdom
24
Drives: 320d M Sport
SJ
That's the one. Just had mine done.Took 30 minutes and that included the car being washed.
I would just wait with the car.Pointless leaving it.
Le Mans blue/ black leather with Aluminum trim/ privacy glass/ xenon's/ black line rear lights/ OEM 18inch M Sport wheel upgrade/ PDC/ blue tooth/ Hi-Fi speaker system/ heated front seats/ storage pack/ auto lights+wipers/ green sun strip/ OEM boot spoiler/
external mirror package.
      02-23-2008, 06:22 AM   #8
roofer
roofer's Avatar
United Kingdom
21
Just reset the service light for the microfilter
But the rear pad warning is now telling me rear pads are worn, and won't reset
      02-23-2008, 07:08 AM   #9
Ant397
Ant397's Avatar
United Kingdom
45
Drives: X5 4.8is, Lambo Gallardo
To reset a brake pad warning, all you have to do is replace a worn sensor and or pads and then turn the ignition off and then back on and leave it for upto 1 minute.
The system works by the sensor comming into contact with the brake discs when they wear and creates an open circuit.
By checking or simply removing the sensor if its defective, leaving the ign on will allow it to reset.
      02-23-2008, 07:15 AM   #10
roofer
roofer's Avatar
United Kingdom
21
It had new rear pads in last month, sensor was undamaged/worn.
      02-23-2008, 07:37 AM   #11
dxb335d
The Tarmac Terrorist
dxb335d's Avatar
England
942
Drives: 997.2 GT3
at what mileage is this thing due?
997.2 GT3
      02-23-2008, 08:29 AM   #12
Chris33
Chris33's Avatar
United Kingdom
24
Mine was done at 30,000.
      02-23-2008, 10:34 AM   #13
Ant397
Ant397's Avatar
United Kingdom
45
You can change them at any time, for the cost I allways put a new one in periodically. They change to a dark grey colour and as all the air that goes into the passenger cabin passes through it and we breath it in, for the cost, I change them anyway when I sense the slightly musty smell... But thats just me.
      02-23-2008, 10:38 AM   #14
roofer
roofer's Avatar
United Kingdom
21
I'll do a battery reset tomorrow, see what occurs.
      02-23-2008, 10:43 AM   #15
Ant397
Ant397's Avatar
United Kingdom
45
Did you try leaving the ignition on for 1 min without the engine running?
      02-23-2008, 11:06 AM   #16
roofer
roofer's Avatar
United Kingdom
21
Yep, thats more an E46 thing tho.
      02-23-2008, 11:07 AM   #17
Ant397
Ant397's Avatar
United Kingdom
45
Nope, far from it.
      02-25-2008, 08:12 AM   #18
m.rk77
m.rk77's Avatar
24
Drives: BMW 335d
see pic
      02-25-2008, 08:35 AM   #19
dxb335d
dxb335d's Avatar
England
942
Drives: 997.2 GT3
at what service is the mirco filer due? (mileage also?)
997.2 GT3
      02-25-2008, 03:37 PM   #20
ShereKhan
ShereKhan's Avatar
United Kingdom
96
Depends where you drive
If you drive in a hot desert - then it'll be round quick.
(Just because there is a hosepipe ban in summer in Essex it doesn't count)
Check yours through your stalk or idrive (delete as applicable).
Mine is going to be due at 43k - but as i've seen it may not really of relevance to any non si cars. As the sparks were changed at 25k ish.
      07-04-2008, 09:22 AM   #21
GrandMasterFlash
Drives: BMW E90 320D
Hi Ant,
I've got the rear brakepad replace warning also. I've tried to reset the warning light but that doesn't work so I reckon the pads are actually worn (there's 50K miles on the car, I bought it with 40K miles). I'm gonna buy the pads and fit them tomorrow if necessary. Do you know does the sensor come with the pads or will it be a separate item? I'm assuming if the pads are OEM that the sensor will be separate..
Thanks in advance.
      07-04-2008, 09:55 AM   #22
Ant397
Ant397's Avatar
United Kingdom
45
Originally Posted by GrandMasterFlash View Post
Hi Ant,
Thanks in advance.
Its seperate and if the light is on, you will need to buy a new one mate.
Search this Thread:
Advanced Search
