BMS meth kit install question.
10-14-2015, 11:32 PM | #1 |
Rep 36
Anyone who has installed the BMS meth kit, quick question. I've finished everything up but the last bit of wiring where the solenoid wires meet. Do i just splice into the (red) power wire that is hooked up to the red fsb fuse wire? So ultimately I would have 3 wire ends inside the wire nut? One coming from fsb fuse side (left) one from the pump (right), and the second solenoid wire (bottom)?
10-15-2015, 07:44 AM | #4 | |
Joint Chiefs of Staff
4918
Rep 115,980
If you want to be fancy you can use a posi-tap. Mike |
