Oh crap, what did I just hear? Horrible sound after a quick sprint...
10-13-2015, 09:18 PM | #1 |
Major Private First Class
449
Rep 1,327
Drives: 2010 E90 335i M Sport
I decide to gun it up this big hill near my house coming home from work. It hauls butt, however, when I get close to pulling into the my garage, I hear a weird rattling sound, like a chatter. A loud chatter. The engine also vibrated viciously I recall and when I pressed the gas to accelerate it would make other terrible sounds. It threw a service engine soon code. Will this code be there even though I have a JB4 tune? I want to read it and find out what happened.
Do I need to use Juice Box 4 Performance Tuner or can I read the codes in the dash using the JB4 steering wheel controls? Thanks Edit: When I turn the car back on, I don't hear the chattering sound. Clutch cooled down? I also want to say I was doing a pull from 2nd -> 3rd -> 4th where I shut it down. My starting speed was probably 20mph or so.
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs Last edited by N54Society; 10-13-2015 at 09:29 PM.. |
10-13-2015, 10:40 PM | #3 |
BimmerPost Supporting Vendor
1334
Rep 1,701
Drives: Slot Machines.. Keep Taking $
Sounds like a limp mode and you have a bank shut down. Car was running on 3 cyl. If you turn the car off and restart it, everything should have been back to normal. If not, then worry.
10-13-2015, 11:00 PM | #4 | |
291
Rep 2,189
The chatter was probably DWFW.
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
10-14-2015, 01:01 AM | #5 |
1334
Rep 1,701
10-14-2015, 02:34 AM | #6 |
449
Rep 1,327
Codes pulled from the dash:
29D0 Misfirings, cylinder 4 2D25 Mass Air Flow Excessive Please correct me if I'm wrong. Those were the two codes I pulled. Nothing else to report...so what do they mean? I just installed my VRSF 7" intercooler last night. Is this related to that? Plugs were replaced at 87k miles on Nov 19, 2013. I'm at 113k miles. Is that considered old? Should I switch the cylinder 4 coil to another one and see if it throws another code? Should I buy some coils and replace them all? Coils were replaced at 42k miles back in 2010. Thanks
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs Last edited by N54Society; 10-14-2015 at 02:41 AM.. |
10-14-2015, 09:48 AM | #9 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
If the plugs have more than 15k change them, if not swap cyl 4 and 5 coils and see if the misfire follows.
10-14-2015, 10:17 AM | #10 |
291
Rep 2,189
10-14-2015, 10:18 AM | #11 | |
3441
Rep 79,211
You're problem is likely the coil and it's easy to find out. Just move the coil to other and see the misfire follows, it's free to try before buying anything. We offer 6 pack coils and 6 pack plugs OEM Bosch if you need them. |
10-15-2015, 12:51 AM | #12 | |
449
Rep 1,327
I switched the coil that was misfiring in cylinder 4 with cylinder 3. Reset the codes. Drove the car and it threw two more codes: 29D0 Misfire Cyl 4 29CF Misfire Cyl 3 I then switched coils from cylinder 3 with 2, reset codes, drove the car and it threw 29CE Misfire Cycl 2. So that coil 4 that was bad, that I switched with 3 which got switched with 2 ended up throwing a misfire code for cylinder 2 (which again, has the original 29D0 Misfire Cyl 4 coil). It looks like I have one bad coil, at least. Here is what the coil from original position/cylinder 4 looked like before a good wipe down:
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
10-15-2015, 09:00 AM | #13 | |
3441
Rep 79,211
10-15-2015, 09:08 AM | #14 |
1552
Rep 3,475
10-15-2015, 09:44 AM | #15 | |
449
Rep 1,327
10-15-2015, 09:46 AM | #16 | |
291
Rep 2,189
10-15-2015, 10:54 AM | #17 |
449
Rep 1,327
I honestly don't think so. I don't ever recall going into the area where the plugs sit and cleaning up. I hope I'm right but I just don't recall it. And it's not leaking any where else. I'll know as soon as I get a replacement coil in there.
10-15-2015, 12:46 PM | #18 | ||
3441
Rep 79,211
If it shows up with oil again then that VCG install didn't go well which is very unfortunate and I feel your pain. |
