Pictures, Video, and Details of my Custom Exhaust System.
10-12-2015, 10:47 PM | #1 |
581
Rep 673
Gentlemen,
I recently had a custom exhaust system built for my N54 E61 and am very happy with the results. Here is the run-down on the system. BACKGROUND For the past 2 years the exhaust on my wagon has gone through many different iterations. First was a simple muffler delete, a fun improvement over stock but it left me wanting more. Next the 2ndary cats were replaced with Vibrant 1792s which offered a slight bump in sound volume. After a while I got bored and decided to have a local muffler shop do a "custom" system for me, the 3' of oem piping (crushed ~2.3") off the DPs was left in place and the rest of the system was comprised of a Magnaflow resonated x-pipe, 2 Vibrant 1792s, and a muffler delete with a small H-pipe before the tips, all piping after the Magnaflow was crush-bent 2.5". Although there was drone in the 2,000-2,500rpm range, this setup yielded a nice smooth sound, in contrast to the flappy, farty, or raspy sound of many N54 exhausts. In attempts to kill the drone I replaced the Vibrant 1792s (12") with their longer 18" siblings. Drone persisted but the sound got slightly softer and quieter. I started to research helmholtz and branch resonators and as an experiment had the old 1792 bottle resonators capped and welded into the muffler section as helmholtz resonators, I figured it could only help, WRONG, drone was worse. Immediately I had the muffler shop cut out everything after the Magnaflow resonator so the system is now straight piped with only the Magnaflow resonator in the mix. Surprisingly the system wasn't terribly loud, louder than before, yes, but with the added volume you got more "real" mechanical sounds. I had enough, after hearing a custom single 3" exhaust on my friends E90 (had RBs, now has an FFTEC 6466) I was convinced that was the way to go. BUILD Initially I ordered a QTP valve and 2 resonators so the system would be Valve Open: 1 resonator, Valve Closed: 2 resonators. I liked the idea of having options but fitting all this after my rear-axle would be a challenge and after hearing the single resonator setup I was convinced it would be quite enough for me. Flash forward to October 2015 and I am discussing my plan with Josh at JFR Motors in Costa Mesa, CA. All is good and I drop my car off the next day with the parts I purchased for the build. Here are the specifics on my exhaust system, keep in mind I have AR "off-road" DPs. Mandrel Bent, Stainless Steel, Tig Welded Vibrant 2.5" flanges Custom 2-1 Merge Collector (made by Josh) IN: dual 2.5" OUT: single 3" Vibrant 63004 4" Flex Section Vibrant 1142 3" IN/OUT "Ultra Quiet" Resonator Custom 1-2 Y-pipe (made by Josh) with dual 3.5" x 12" Slash Cut Tips (Black) RESULT The end result surpassed my expectations, drone which used to plague me between 2,000-2,500rpm is gone, there is some resonance around 1,500rpm but this is only noticeable when putting around parking lots. In-cabin sound levels are very manageable and I would say lower than my old system. The exhaust is now more 2 faced meaning when driven conservatively it is rather tame and civil, but when given the beans really rips. The WOT sound is great and IMO one of the best sounds produced by a twin turbo N54. Most other N54 exhausts I like are paired with single turbos, like my buddies FFTEC E90 (custom exhaust by Filthy Fabrications) and the 829whp E90 by Motiv (exhaust unknown but Youtube it). I can't stand rasp and I am happy to say that this system is also rasp free. In addition to the increased flow (will dyno again soon) and lighter weight, there is a significant jump in turbo noise, mainly off throttle whistle, I love it! I think this is in part due to the large diameter piping and cleaner routing. The car sounds serious! As my wrenching skills progress along with my wagon obsession, I become more hesitant to let others work on my car. But after seeing Josh's shop, hearing his thoughts, and seeing his work, I trust him 100% and happily recommend him to others. His shop is called JFR Motors and is located in Costa Mesa, CA. (Orange County) MEDIA Here is a short compilation of videos I have thus far, there will be more to come. Cold Start Freeway Cruising Here are some pictures of both my old and new systems. Although not all but most photos will have a corresponding description. If you are local and want to hear it, let me know! Evan My original muffler delete The system after removing 2ndary cats and oem resonator: 3' of oem crushed 2.3" piping, Magnaflow resonated x-pipe, 2.5" crush bent piping. Vibrant 1792s, H-pipe muffler delete, dual 3.5" slash cut tips Oem ***-back section Vibrant 1792 (12") replaced with 1793s (18") Old H-pipe muffler delete Vibrant 1792s capped and welded in as helmholtz chambers, this did not work. Parts for the custom system At JFR Motors, build in progress Josh doing work Merge collector welded, flex section tack welded. Blurry detail Y-Pipe/Tips Detail 1 Detail 2 Detail 3 Detail 4 Nice! Detail 5 V-band detail Complete 1 Complete 2 Complete 3 (sorry for the angle) Rear section complete Last edited by ucsbwsr; 10-13-2015 at 11:39 AM.. |
10-21-2015, 09:45 PM | #4 | |
581
Rep 673
Evan |
10-21-2015, 10:29 PM | #5 |
71
Rep 510
This exhaust setup is, undoubtedly my favorite sounding n54 setup! The rasp has been eliminated and the turbo spool at idle is superb. I am currently running dual resonators in place of secondary cats and straight pipes all the way back. The rasp is somewhat terrible, as I thought the resonators would've removed such. Any recommendations on how to imitate this sound but for the e92 n54 (dual pipes all the way back)?
'2018 F87 M2 LCI | LBB | GC Camber Plates | Ohlins R&T 90/190N/mm | 18x10 et33 square 275/35 | MPe | Poly Transmission Mounts | Recaro Sportster CS
10-21-2015, 10:35 PM | #6 | ||
319
Rep 891
Formerly Ian_N54 - @b1mmr
10-22-2015, 10:00 AM | #8 | |
581
Rep 673
Crossing/mixing the exhaust streams should help with the rasp, that is why I originally went with the Magnaflow resonated x-pipe, it killed 2 birds with one stone. It sounded good too, the only problem was drone. So far I am yet to hear that single pipe N54 system that sounds bad, so if you are inclined I think that would be the way to go, if not adding an x-pipe, especially a resonated one should be a step in the right direction. I am no expert, just making some suggestions based off my personal experience and some research I have done so take it for what it's worth, Evan |
10-22-2015, 10:13 AM | #9 | |
581
Rep 673
I see you are in Orange County. If you like we can meet up and I can show you the exhaust in person, give you a ride, and have you fully experience the system. Let me know! Evan |
10-22-2015, 05:29 PM | #10 | |
71
Rep 510
10-23-2015, 11:04 AM | #11 | |
581
Rep 673
If you want to pursue something like this I would recommend buying a merge collector from www.mandrel-bends.com along with the additional components of your choice for the build. Evan |
10-23-2015, 12:28 PM | #12 | ||
99
Rep 565
Drives: G20 M340i
You have motivated me to go out and do this on my own, following your example (tired of waiting for VRSF) and now I think I have a better idea of what I want. Really like the single side exhaust too. |
10-24-2015, 02:31 PM | #13 |
581
Rep 673
10-24-2015, 02:46 PM | #14 |
3788
Rep 5,776
Gotta say I'm not too fond of the wagon thing, but you have a pretty damn cool one. Looks good, sounds good and has all that power. Changed my wagon view..just a little.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
10-24-2015, 05:23 PM | #17 | ||
581
Rep 673
Evan |
10-25-2015, 09:29 PM | #18 |
Jedi samurai ninja turtle
619
Rep 3,021
Drives: X3 M40i 2018
Wondering if that resonator will fit under a 335 without hanging too low?
10-26-2015, 10:47 AM | #19 | |
581
Rep 673
It is not a very large unit, the dimensions can be found on the Vibrant website. Last edited by ucsbwsr; 10-26-2015 at 10:54 AM.. |
10-26-2015, 01:51 PM | #22 |
14
Rep 208
Props. This setup is very close to what I want. I've been thinking about switching to a single outlet bumper on my 335xi.I think these straight 6s sound way better with single exhaust. Less whiny honda, more torque monster.
