X-pipe vs Resonators?
10-12-2015, 08:59 PM | #1 |
94
Rep 268
Ill preface this by saying that I have an N55, not an N54, It's just that the n54 section sees a lot more action, and I'd like to get as much input as I can before I head over to the muffler shop. + its my understanding that the exhausts are pretty similar.
I installed a catless downpipe on my E90 last weekend, and I'm not a big fan of how the car sound now(I also have the PE mod). It's a little too loud, drones a little too much, and my car sounds like a diesel truck down low, and rasps up high. I've got my hands on some resonators, but I'm wondering if an X-pipe will help with the sound at all. I know the E92's have an X-pipe, and the E90's have an H-pipe. Anyone have any idea if I should try switching to an X-pipe first, or just have the resonators put on, and not bother with switching out my current H-pipe. Will an X-pipe affect the sound level as well, or just the tone of the exhaust? Any input is appreciated Thanks |
10-12-2015, 09:18 PM | #2 |
393
Rep 1,371
I don't know what the N55 is like exhaust-wise but I have an N54 and went from resonator to x-pipe and it's defnitely a little louder. Even more so with the catless downpipes I just had installed. So if you're looking to make it quieter, an x-pipe is not the way to go.
10-13-2015, 09:47 PM | #3 | |
23
Rep 282
Agreed. When i got rid of my resonator and installed the x pipe it did get louder. OP I read that kittyless pipes and performance exhaust causes drone. Get a resonator installed. |
10-13-2015, 10:17 PM | #4 |
137
Rep 589
Drives: E90 M3/E92 M3
An x pipe would probably amplify the sound. What I would do is resonator delete with x pipe and secondary cat delete replace with vibrant resonators. Not sure how the exhaust system differs from the n54 to n55 but that's what I would do.
10-13-2015, 10:48 PM | #5 |
94
Rep 268
Sounds about right. That's essentially what I'll be doing. I have catless dp, no secondary cats to begin with, and I already deleted the resonator in the muffler.
10-13-2015, 10:50 PM | #6 | |
137
Rep 589
10-13-2015, 11:12 PM | #7 | |
94
Rep 268
Sounds like a loud diesel truck below 3k, and above 3k it has intermittent rasp throughout the rest of the rev-range. Ill be having 1790 vibrant resonators put on by (hopefully) Friday. Weel see how it turns out. I'll be putting up the video results in this thread for anyone interested: http://www.e90post.com/forums/showth...1113288&page=2 |
10-13-2015, 11:20 PM | #8 | ||
137
Rep 589
10-14-2015, 09:41 AM | #9 | |
450
Rep 1,369
Drives: F80 M3 6MT
N55's also do NOT have secondary cats. I know this as I bought an N55 exhaust to use in my setup. For me, I kept my secondary cats and have no drone with a similar exhaust setup to you. The only way to reduce your drone is with resonators. I would advise Vibrant resonators and I would install them in the midpipe section prior to the X-pipe. For reference... N55 Midpipes are the first pic. Next two are an e90 n54 rear section underneath an e90 n55 rear section. You can see the resonator vs the X-pipe. The n55 section also has DiMisa tips already installed.
15 F80 M3 Mineral Grey/Black 6MT
10-14-2015, 11:07 AM | #10 | |
94
Rep 268
10-14-2015, 06:31 PM | #11 |
255
Rep 554
Drives: 2013 335is E93 6MT
I've got catless DPs and a 335is exhaust, with rasp/drone. A number of N54 folks have replaced their secondary cats with the Vibrant 1792 resonators and swear by the set up. (See first pic below.) At least one guy, though, has kept the secondary cats and put Vibrant 1790 resonators right after the x-pipe. (See second pic below.) Now you suggest placing 1790s in the before the x-pipe. In the third pic below (from a stock N55 E90 Xdrive, close enough) where would that be, immediately before the x-pipe, i.e., in between the x-pipe and the brace? And what's the advantage of having it before the x-pipe rather than after? I also can't figure out why some people go with the 2.25" 1790 and others the 2.5" 1792. One or the other has got to be a bit more difficult of a welding job.
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings |
10-20-2015, 10:51 AM | #12 | |
450
Rep 1,369
Drives: F80 M3 6MT
I would get the 1792's and have them welded in the midpipes where the secondary cats normally go, before the x-pipe. You will want some spacing before the x-pipe. I have never seen them installed after the x-pipe, that to me seems more complicated. I'm not a flow engineer, but I would think you would not want to bottle up everything at the end of the exhaust run with resonators and then mufflers. The reason a vast majority go with the 1792's at 2.5" is because the stock exhaust piping is 60mm, which equates to 2.362". You are better off having area for flow then reducing it down. Really splitting hairs, and the welding should not be a problem for most reputable shops. Good luck! Post pics!
10-20-2015, 01:07 PM | #13 | |
255
Rep 554
All that remains is the placement. That's apparently going to have to wait until I get to the exhaust shop. I agree, probably the best place would be further up in the mid-pipe area -- which is why I asked you about that. With the exception of that one artful post-xpipe job, everyone seems to have just swapped out the cats with the resonators. I'd like to avoid doing that, but I will if I have to because that 4500-5500 RPM rasp with catless DPs is just so incredibly nasty/tacky/ricey.
10-21-2015, 07:22 PM | #14 | |
450
Rep 1,369
Drives: F80 M3 6MT
Yes there definitely is rasp in that range. I see you are an e93 and in FL, so I'm assuming you have the droptop down often and are more susceptible to the exhaust notes than I am in my e90 in Michigan with four seasons I would definitely do them upstream and keep the secondary cats.
10-21-2015, 11:02 PM | #15 |
///Project Aura
390
Rep 889
Don't E92 N54's have an X-Pipe? I could've sworn mine had one when it was lifted at the Muffler shop. My E92 N55 doesn't have an X-Pipe and it seems to be a bit louder with the same exhaust setup.
10-22-2015, 04:50 AM | #16 | |
137
Rep 589
10-22-2015, 07:31 AM | #17 | |
255
Rep 554
10-22-2015, 07:34 AM | #18 |
Driving cars and riding bikes really fast
285
Rep 1,002
Where are you guying purchasing these resonators?
335i, sport pkg, 3 pedals, Blacked out, LED markers, OZ Ultraleggera wheels, Firestone Indy 500s, x-pipe, vibrant 1792, PE mod
MHD stage 2+, BMS DPs, ARM charge pipe, Tial BOV, ARM FMIC, dual cone, CSF radiator, M3 control arms, sways, HAWK pads. https://www.strava.com/athletes/8309149 Follow me on Strava |
10-22-2015, 11:12 AM | #19 |
255
Rep 554
Where else? Amazon.
10-22-2015, 12:16 PM | #20 |
450
Rep 1,369
Drives: F80 M3 6MT
I would agree with that statement knowing what mine smells like.
11-06-2015, 05:13 PM | #21 |
94
Rep 268
Done!
turbonkicks0.00 |
