10-12-2015, 12:40 PM | #1 |
55
Rep 368
Drives: 2016 M235i
Thoughts on the Dinan Performance Springs
I would like to lower my M235 just a enough to get rid of the gap in the wheel well. Does anyone that has these care to comment?
Thinking Dinan as I want to keep my warranty intact.
2016 M235i - Mineral Gray
10-13-2015, 12:17 AM | #2 |
424
Rep 980
I might do the springs on my 228i, although inevitably the labor will be expensive. Two pieces of advice, FWTW: (i) you will be better off doing this through a specialist tuner shop with a well-established Dinan license rather than a dealership, even one authorized to install Dinan products. There was a horror story in these forums recently from a guy whose car was all but ruined when a non-Dinan BMW dealership (also his employer, ouch) installed his springs upside-down. He was $1000 down with a crippled car and no warranty on the work. Always use a high-quality Dinan performance shop. Finally, (ii) make sure you get the ride kit with the springs. Good luck and please keep us posted.
10-13-2015, 09:40 AM | #3 |
22
Rep 64
I had the springs installed on my m235i about 2 months ago.. I definitely recommend the upgrade. I have been using the same high quality shop since I first got my license, (I'm 35 now) so I trusted them to install them properly. In my opinion, this is the way the car should've came. It handles better, the gap is closed giving it a nice even look front to back, recovers from bumps faster, rolls less, and in sport mode isn't harsh at all. To me, it feels just right. Hope this helps.
10-13-2015, 11:49 AM | #4 |
55
Rep 368
Drives: 2016 M235i
Thanks. Anyone have a good rec in the San Diego area?
10-13-2015, 12:39 PM | #5 | |
94
Rep 244
10-13-2015, 01:02 PM | #7 | |
55
Rep 368
Drives: 2016 M235i
10-13-2015, 01:16 PM | #8 | |
65
Rep 274
18s on dinan springs: |
10-13-2015, 02:23 PM | #9 | |
117
Rep 292
2015 M235i BSM / 2011 X5D AW
10-13-2015, 02:26 PM | #10 | ||
55
Rep 368
Drives: 2016 M235i
10-20-2015, 11:31 AM | #15 |
1753
Rep 2,942
The M Sport suspension drops both axles 10mm. The Dinan springs drop the front axle 1/2 inch (13mm) and the rear a full inch (25mm). Simple math says the Dinan springs will drop a car with M Sport suspension 3mm in the front and 15mm in the rear.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
10-24-2015, 07:43 PM | #16 |
253
Rep 1,334
Here is mine on the Dinan Springs...do not bother with those overpriced E30 M3 bumpstops (which you can just get at a dealership) that Dinan calls a supplemental comfort kit. Just cut your stock ones (no shock disassembly needed) takes 5 min each side and you get the same smooth ride. cheers.
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
10-25-2015, 01:27 AM | #17 | |
559
Rep 1,503
FBO M235i r
F80 M3 |
10-25-2015, 07:34 PM | #18 |
253
Rep 1,334
No, it will not effect the ride quality when you go back to stock.
10-26-2015, 12:05 AM | #19 |
559
Rep 1,503
I wonder if the same could be done for H&R springs...
FBO M235i r
F80 M3 |
10-26-2015, 12:27 PM | #20 |
253
Rep 1,334
Yes. I will bet after 10K+ the car will get bouncy...at least that has happened with me on every H&R spring-only setup I've had unless I cut or got shorter bump stops. There simply isn't enough shock movement over time and the shock will surely lose its rebound effectiveness. good luck!
