Help bleeding clutch
10-10-2015, 06:29 PM | #1 |
37
Rep 335
Not sure if this is the right section, if not mods can you please move it.
Did the CDV delete and can't for the life of me bleed this clutch. Literally nothing comes out the bleeder valve when i open it. Fluid is a little more than half way full (plan to get more tomorrow). I tried pumping the clutch peddle then going to open the bleeder valve and nothing comes out. I tried using one of those shitty advanced auto parts vacuum pump kits and still not getting any fluid out. Can someone tell me what I'm doing wrong here. |
10-10-2015, 07:04 PM | #3 |
319
Rep 1,023
What he said. Easiest way is a pressure bleeder or vacuum bleeder. Without those things, you need 2 people. Push down clutch and hold, crack open bleeder until fluid slows (but before it stops!), then shut bleeder and release clutch. Repeat until satisfied.
If you don't have a helper, you can use a piece of 2x4 or anything else to prop between the clutch pedal and the seat. Wedge it depressed, then crawl under and bleed the clutch as above.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
10-10-2015, 07:08 PM | #4 |
37
Rep 335
I pump the clutch, push it all the way down (clutch basically just drops to the floor, won't come up unless I pull it), put a brick on it to make sure it stay down, open the bleeder valve and nothing comes out
10-11-2015, 04:24 AM | #5 |
7
Rep 131
I've had the same problem doing my CDV delete.
You should try to fill it from the underside, press the brake fluid from the bleeder up back to the resevoir. This will push the trapped air upwards. Best to do this is to get a small pump can, fill it up with some brake fluid and attach a small hose from the can to the opened bleeder. Pump until the air bubbles stop mounting up in the reservoir. Good luck Steve |
10-11-2015, 06:01 AM | #6 | |
827
Rep 3,189
It has to be pushed right to the floor before you crack and elevate fluid/air until you get 100% fluid and bleed a tiny bit out to gain fuul compression in the fluid line. Make sure you press and hold clutch 100% then bleed. Repeat repeat repeat until clutch is good |
10-19-2015, 07:05 AM | #9 |
37
Rep 335
Borrowed the motive bleeder from someone local, and omg that thing makes this job so easy!! Def kicking myself for not picking one up before doing this job.
10-19-2015, 04:24 PM | #10 |
319
Rep 1,023
Get the fitting for your brake reservoir too. Jacking the car up is the hardest part of my annual brake bleeds.
10-19-2015, 04:52 PM | #11 |
79
Rep 540
Every clutch I've done I do the same way, let it gravity bleed for 5 minutes watching the level, pump/hold method.
Sounds like you need some patience Pressure bleeders will work as well, just gravity bleed it first, makes a world of a difference |
