Vcg bolts?
10-08-2015, 05:17 PM | #1 |
147
Rep 796
Vcg bolts?
Have a vcg leak,oil residue and gunk along side the engine...i already purchased the gasketand im aware i need to change the aluminum bolts but i keep seing different part numbers for it can someon confirm for me please
10-08-2015, 10:24 PM | #2 |
51
Rep 308
Drives: 2007 328i
Do yours have blue on them? Mine didnt and even the dealer said I didnt need them.
10-09-2015, 08:12 AM | #4 | |
147
Rep 796
10-09-2015, 08:14 AM | #5 | |
147
Rep 796
10-09-2015, 08:42 AM | #7 |
3973
Rep 7,215
aluminum bolts are for 2 things - to prevent galvanic corrosion on magnesium parts, and for reduced weight.
on the 328 they switched to a plastic valve cover, and the head is aluminum, so corrosion isn't an issue. BMW switched several of the bolts to steel - there's no reason an N52 with a plastic valve cover would require aluminum valve cover bolts. Whether BMW still used them or not is the question - the OP will have to check the bolts that are there to know. It would be simple to check with a magnet.. |
10-28-2015, 11:35 AM | #8 | |
147
Rep 796
10-28-2015, 12:07 PM | #9 |
1645
Rep 2,494
Not only N54.
Go pull the beauty cover off your engine and look at the heads of the VCG bolts. If they have blue paint on them they are Al and one-time use. If not, then stick a magnet on the head of the bolt to confirm that they are steel. If the magnet sticks then you don't need new bolts.
10-28-2015, 01:37 PM | #10 |
FSAE Dude
62
Rep 759
2006 had a magnesium valve cover with blue aluminum bolts that you would need to replace. After that, it was a plastic valve cover with reusable steel bolts.
2007 TiAg 328xi: AA Tune, AFE intake, Full exhaust, 335xi Brakes, H&R RSB, UUC FSB, H&R Sports, Billy Sports...BBS SR 17x8
1985 Gazelle Beige 325e: Poly everything, e24 3.25 LSD, 225 lb weight reduction, Corbeau FX1, Shifter machined by me, roll bar, harness, all the other goodies. My "Racecar"...15x7 BBS RA |
10-28-2015, 08:02 PM | #11 |
200
Rep 1,834
Drives: '05 E90 330i Manual
Mine has this valve cover and of course has the blue painted aluminium bolts.
