Aquamist HFS4-V3 discussion - 335D
10-08-2015, 02:01 PM | #1 |
400
Rep 5,623
So i'm thinking of fitting a meth kit, but part of me is a bit concerned if my car runs even more torque what the damage could be to my gearbox.
Is there anything that i can do, preventative wise, to the gearbox that would enable it to handle more torque? Any parts i could replace for stronger ones? Last edited by mob17; 10-12-2015 at 10:14 AM.. |
10-08-2015, 09:25 PM | #3 | |
106
Rep 292
Drives: 2011 335d
Garage List 2017 Audi Q7 [0.00]
2011 BMW 335d [0.00] 2006 Nissan Titan SE [0.00] 2008 MB CLS550 [0.00] 2012 BMW X5 SAV [0.00] |
The only thing that I have done to the transmission is change the fluid/ filter, the mechatronics seal/sleeve and several of the other seals and the transmission is performing fine. I think a lot has to do with the tune that you are running and when the torque converter nannies kick in. The banned one is the only one that I know of Stateside that is running a modified/built tranny. Not sure who is out there in Europe that can help you with this. What are the guys at Madness Motorsport and ProfiTuning running on their modified 335d cars with hybrid turbos? As far as I know they are running stock transmissions. |
10-09-2015, 10:30 PM | #5 |
106
Rep 292
Drives: 2011 335d
No,the one that came with the kit was not sufficient enough dealing with the 40 lbs of boost that I was pushing at full throttle. Whilst testing and fine tuning the car on the street the boost vacuum line popped off. The upgraded boost controller accommodates higher boost levels in addition to utilizing a MAP sensor as opposed to a boost vacuum line to measure boost hence initiating the water/meth pump.
10-10-2015, 12:20 AM | #6 | |
671
Rep 1,442
10-10-2015, 01:38 AM | #7 |
106
Rep 292
Drives: 2011 335d
10-10-2015, 09:19 PM | #9 |
798
Rep 1,633
Just want to add some clarity ...
If a proportional controller (not staged system) is running off of boost, it is doing so with a MAP signal, either internal or external. MAPs are rated by their full scale pressure. Clearly a higher rated MAP was needed in NC335d's case. The same controller can work for many different MAPs. H20/methanol injection provides 1) coolant to control combustion temperatures 2) additional fuel for heat energy. If a fixed boost limit occurs throughout the powerband at full load, a boost signal cannot track any variation in AFR or temperature. These things are often correlated to MAF or RPM. That is where the AEM controller show's it's superiority. Because the 335d MAF is a frequency based sensor, AEM's frequency signal processing can be used for either parameter. Which is better depends on the specifc application. |
10-11-2015, 05:41 PM | #10 | |
671
Rep 1,442
10-11-2015, 07:50 PM | #11 | |
798
Rep 1,633
Just to break a paradigm, I'm considering controlling H20 and methanol separately. Obviously, the methanol needs to be treated as a fuel, with safety in mind. Then H20 can be used in closed loop control of exhaust temperature. |
10-11-2015, 09:04 PM | #12 |
144
Rep 316
Agreed. I've installed a few of them and they are top notch. Their controller is a standalone ecu for all intensive purposes. The most current HFS4-v3 version is fully programmable and takes injector duty, rail pressure, and map signal to determine the flow. I dropped them an email last week about installing the system on a 335D and if they had any specific recommendations about grabbing an injector signal with our multiple injection events.
10-11-2015, 10:27 PM | #13 | |
1322
Rep 700
10-11-2015, 10:33 PM | #14 |
144
Rep 316
The really nice them about them is operating like a gasoline efi fuel system with constant pump pressure and PWM controlled delivery, you can do one nozzle in front of the turbo and one post IC to get the greatest possible benefits. With the much finer atomization at lower delivery levels, damage to the compressor wheel isn't a concern. It's the route I'll be heading when funds permit.
10-12-2015, 04:13 AM | #15 | |
1322
Rep 700
10-12-2015, 07:44 AM | #16 | |
798
Rep 1,633
Multiple injection is an issue if you plan to inject at part throttle settings. Full throttle, post and pre injections go away. Aquamist is trying to hit a specific fuel to water ratio (that's a little too simple for a diesel as AFR needs to be considered as well, That's why they added the auxiliary input to get MAF). To do that they are trying to measure fuel flow with duty cycle and pressure. I think if you just take an rpm signal (you can tap one off the OBD port), combined with MAP and rail pressure you can get very close. |
10-12-2015, 07:53 AM | #17 |
798
Rep 1,633
Damn, I just did what I don't like doing. These water injection posts are way off subject. We should probably start a new thread if we are going to continue down this road.
Is there a good way to grab the last group of posts and move them? |
10-12-2015, 10:14 AM | #18 | |
400
Rep 5,623
I will amend the thread title. |
10-12-2015, 11:51 AM | #19 |
144
Rep 316
Now that we're not derailing anymore, I just got this from Aquamist this morning:
"I think the 335D has solenoid type injectors. The N54 335i has piezo-type injectors. The HFS4 can read both. The 335D responses very well with wm injection. See attached. If you order the system with a "335d" comment at checkout, I will put in the appropriate documents. Richard aquamist direct" Maybe the 335D's in the UK had solenoid injectors? I'm 99.9% sure ours are piezo here in the US. Either way, good to know it works with any of them! I attached the dyno they sent me also. |
10-12-2015, 01:27 PM | #20 |
400
Rep 5,623
I've emailed the person whose dyno that is to get some more info, but yet to hear anything. But the gain on that is very impressive, never thought meth would give such a big increase.
When speaking with Richard, i think what he said was that the IDC and MAF are mainly used for the injection calculation, and boost makes a small percentage of the calculation. I'm just wondering what the aux input should be used for. |
10-12-2015, 04:20 PM | #21 | |
798
Rep 1,633
That dyno curve is interesting. Looks like the added methanol HP is dimishing with rpm after 3,000 rpm. That is representative of a boost only curve on a stock 335d. Not what I would have expected. |
10-12-2015, 04:30 PM | #22 | |
614
Rep 2,410
2011 335d 11.68 @ 125.71 mph 1/4 mile NHRA certified track
Ram Cummins with lots-o-mods |
