WOT 4th-6th.. Bad?
10-07-2015, 04:19 PM | #1 |
75
Rep 731
Drives: 2008 335i 6MT
What's up guys. I was told to only run my car WOT for 2-3 gear pulls because "doing multi gear pulls up to high speeds puts extreme back pressure on the turbos even with downpipes"
I would like to know what everyone does when they wanna go past 110ish mph? Obviously you can just cruise over that but even if you run the car at the track you still have to be WOT in 4th maybe even 5th (never ran my car yet so idk) Any solution to this?
2008 335i Coupe / Alpine White / 6MT / Fully Built Motiv Closed-Deck Motor / Motiv ST Kit / XR 105/69S / Motiv Twin Disc / VRSF 7.5 FMIC / ActiveAutowerke Exhaust / EOS Intake Manifold w/ 1050cc injectors / TiaL BOV / External VTA PCV / Quaife LSD / DSS Axles / KW V3Coilovers
10-07-2015, 05:10 PM | #2 |
65
Rep 385
You're a 6MT so redline in 3rd is what, about 115 or so? Redline in 4th is 146 I think.
In a general sense a more conservative tune (i.e. not on the ragged edge) will tolerate the much longer time under high load. Just make sure your FMIC is up to it and your fuel is good.
2007 E90, 6MT, VRSF 7" FMIC, RR DP's, Vargas Stage 2+ (19t unclipped), CP-e Charge Pipe/Tial BOV, BMS DCI, Fuel-it! Stg 2 LPFP, E66, 118k+ miles Brentuned
10-07-2015, 05:12 PM | #3 |
3441
Rep 79,211
Any use of a machine will put more wear on it, especially with more load and heat. Whoever told you that is partially right except for the fact that it's an overly conservative blanket statement. It would only be an issue if you were doing it daily or exceptionally often.
How often do you find yourself in excess of 120MPH?? PS I've put this car and all my others past 150 on dozens and dozens of occasions. Still going strong. IMO don't worry about it. |
10-07-2015, 05:13 PM | #4 | |
75
Rep 731
http://www.datazap.me/u/damonp335i/l...11-12-13-14-26 I just don't wanna blow the thing up. I had it up to 6000rpm in 6th if top of 4th is 146 I had to be going 170+.. Never figured it out
10-07-2015, 05:14 PM | #5 |
215
Rep 1,818
6th puts the most load on the motor, combine that with the longest gearing and slowest accelerating gear and you can wind up with an expensive paperweight on your hands
and, like it's been said, there's never a reason to go full load in 6th for long anyways, downshift if you need to accelerate |
10-07-2015, 05:15 PM | #6 | |
75
Rep 731
10-07-2015, 05:16 PM | #7 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
Never heard of that before. I hammer it for 1/2 mile events, three gear logs, and 1/4 mile simulations with my Vbox. I run a very aggressive setup on stock turbos and my logs are perfect. And if my stock snails pop, oh well, on to Hexons but I certainly don't worry about it.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
10-07-2015, 05:17 PM | #8 | |
3441
Rep 79,211
Just make sure your datalogs are good and the octane is sufficient. I know guys with nitrous have the 15 second rule but that's because nitrous has insanely hot EGT and combustion temps. We are nowhere near those levels of heat. |
10-07-2015, 05:18 PM | #9 | ||
75
Rep 731
Any rough idea of what 6k rpm in 6th gear is speed wise?
10-07-2015, 05:19 PM | #10 | |
75
Rep 731
10-07-2015, 05:20 PM | #11 |
3441
Rep 79,211
10-07-2015, 05:22 PM | #12 |
75
Rep 731
I have a log of that but I wasn't logging vehicle speed and I doubt I'll ever get that good of an opportunity to go that fast again to find out how fast I was going but had to be better then 165
10-07-2015, 05:23 PM | #13 | |
3441
Rep 79,211
I leave those top speeds runs to my z06, it's a little more stable and has better brakes haha. The C6Z will do nearly 200 in 5th. I haven't gotten there yet. |
10-07-2015, 05:25 PM | #14 | ||
Sua Sponte
1299
Rep 2,850
10-07-2015, 05:29 PM | #15 | ||
75
Rep 731
10-07-2015, 05:31 PM | #16 | |||
75
Rep 731
10-07-2015, 05:45 PM | #17 | |
3441
Rep 79,211
C6Z can go 10's stock on DR (as long as you can drive and have a good track/DA/conditions). I went on street tires and cut 11.5 with a horrible 60 foot. The Z06 does respond to boost and cam. I picked up 90WHP with a Cam only. The problem with the C6z is the Ls7 block is too thin. It cant handle as much boost or power as the LS3. If you have a C6Z on stock block, you shouldn't go much past 620WHP or you are playing with fire. The block is just too thin. I've been debating on putting a blower on it for a while but I think I'll leave it alone for now. |
10-07-2015, 09:34 PM | #18 |
Boost
1354
Rep 3,692
Drives: 135i M-Sport
Lol I was just trying to scare some sense into you to deter you from winding it out to Redline in 6th gear with a tune that isn't completed yet. That is how you blow things up... We're almost dialed in!
10-08-2015, 08:44 AM | #20 |
3441
Rep 79,211
10-08-2015, 08:51 AM | #21 |
2134
Rep 3,554
I would follow the advise from your tuner and not run to the internet for advice. But thats just me.
Running to redline in 6th with an incomplete tune on a stock LPFP on e50 is just asking for trouble unless the tune is dialed in. |
10-08-2015, 12:00 PM | #22 |
298
Rep 584
