ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M4 GTS Discussions
      10-07-2015, 11:06 AM   #1
04cobra
633
Drives: 2015 M3 - 6MT
Frost proof water tank
I didn't realize this was a thing, anyone know how this works? It gets subzero here in Minnesota.
      10-07-2015, 11:46 AM   #2
Ian1973
736
Drives: 15 M3
a heater I would guess. The water in the lines supposedly drains back to the tank that has a heater I'm sure.
I would be suspect of it if I bought one and wanted to drive in 0 deg F temps.
But it's most certainly not meant to be a daily driver in the least.
      10-07-2015, 12:27 PM   #3
Daft
Daft's Avatar
384
Drives: 2021 M2C
2003 BMW M3  [10.00]
2011 BMW M3  [9.71]
Can't you just mix in some methanol to prevent freezing?
      10-07-2015, 01:00 PM   #4
MChat
MChat's Avatar
Drives: '16 M3 (en route)
That would be my suggestion. IIRC, a 40/60 mix of water/methanol starts to become flammable, hence most suggest a maximum of 50/50. Also I believe a 75/25 mix is good to about 0 degrees Fahrenheit. Windshield washer fluid that is good to -20F is 33% methanol by weight (although it may have some other winterizing additives).
Also, I run only distilled water and methanol in my system. Tap water around here is way too hard to run through an injector. I guess you could run filtered water, but really distilled water is cheap and readily available at the local supermarket.
I have a clear white 5 gallon "race" fuel can. I dump in 2.5 gallons of distilled water (they sell distilled water in 2.5 gal jugs) then fill it with methanol. That 5 gallons will generally last me about 3 months or so.
- Michael
2016 BMW M3 (stock)
2005 Jeep LJ (slightly modified)
      10-08-2015, 07:08 PM   #5
Ian1973
736
Drives: 15 M3
Well the customer is going to have to refill this bottle, I highly doubt most people want to deal with methanol, or the governments around the world want normal people dealing with methanol. I would venture a guess that's why it's only water.
      10-08-2015, 07:21 PM   #6
chris719
7273
Drives: '08 M Roadster
Methanol evaporates very quickly and most windshield washer fluid contains it, I don't know why it would be dangerous to have a moderate percentage.
Search this Thread:
Advanced Search
f80post
