09-23-2015, 03:53 PM | #1 |
683
Rep 1,124
Error message coding F16
I'm trying to help someone get some coding done. I get this error message on about 4 CAFD's :
cafd_000000b6-012_003_012 Fehler: CPS read from ECU "ECUId:SM2_0x6E" failed! [C070] openECUConnection for link SM2_6E_ETHERNET failed with error MCDError Severity: 2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Vendor Description: provided name SM2_6E_ETHERNET doesn't map to an item [1694] Any ideas? I'm using Esys Pro 3.24.3 |
09-26-2015, 06:44 PM | #3 |
Don't care
117
Rep 224
Did you use target selection F025 (without the _DIRECT)?
Radio buttons: Are you selecting "Connection via VIN"? Is "Read parameters from VCM" checked? Last edited by TMD29; 09-26-2015 at 07:09 PM.. |
