alternator mounting bolts...torque value
09-03-2015, 11:56 AM | #2 |
1007
Rep 2,109
See here, but this is only if you have NEW bolts! They are aluminum bolts AND torqued to yield, so if you have to reuse old ones, just use feel and common sense tighten it. Don't want to break the already stretched aluminum bolts. Then order new set of bolts and replace them earliest. If you buy a set, set comes with torque values in the instructions.
Also note they have updated the torque on the idler pulley bolt: https://wiki.bentleypublishers.com/d...que+correction |
09-03-2015, 03:35 PM | #3 | |
74
Rep 776
09-04-2015, 11:06 AM | #5 |
74
Rep 776
01-06-2020, 09:07 PM | #6 |
Rep 24
I just took out the bolts from my 2011 e90 n55 and they are definitely grade 8.8 steel. It’s stamped on the bolt. Also, tested with a magnet so def steel. No need to replace steel bolts. Not sure if torque values though still looking. Edit I’m seeing most bolts are aluminum. Maybe mine were already replaced with steel?
01-06-2020, 10:31 PM | #7 | |
2442
Rep 4,330
OP had an n52. N55s are aluminum blocks and can have steel fasteners. |
01-07-2020, 11:22 AM | #9 |
1918
Rep 13,116
