08-24-2015, 03:50 PM | #1 |
BimmerPost Supporting Vendor
9575
Rep 10,869
IND | BMW M Performance F82 M4 Illuminated Door Sill Set
Genuine BMW M Performance LED door sills illuminate to greet you upon opening your doors. Easy to install and each powered by two small lithium batteries, the door sills are a subtle way to add a bit of flair to your M4. BMW M Performance F82 M4 LED Illuminated Door Sill Set $284.00 Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com BMW M Performance F82 M4 LED Illuminated Door Sill Set may be viewed here in our online store: https://ind-distribution.com/product?sku=BMWP-F82-DS
09-09-2015, 03:59 PM | #3 |
9575
Rep 10,869
Recently installed in a local client's M4. Pretty neat!
12-08-2015, 10:00 AM | #5 |
9575
Rep 10,869
Installation is very simple. The original door sills can be removed by lifting from outer corners of the black surround, new door sills snap in.
Each kit will come with several small magnets and adhesive foam tabs. Once the door sill is installed, set a magnet somewhere between the '///M' and 'P' in Performance lettering. It should move and align itself somewhere in the general area once doing so. Slowly close the door until you hear a 'click' which will be the magnet flipping up and attaching itself to the metal underside of your door. Gently open and close the door several times to ensure the magnet triggers the LED on the door sill. Take one of the foam tabs and once you have removed the adhesive protection film, attach the tab over the magnet and to the door - securing the magnet in place.
Mousejunior122.00 |
12-08-2015, 08:15 PM | #7 | |
560
Rep 1,503
FBO M235i r
F80 M3 |
12-09-2015, 11:29 AM | #8 | |
9575
Rep 10,869
It appears to take a slim watch battery. We did not check in specific.
06-13-2016, 03:51 PM | #10 |
9575
Rep 10,869
Yes, you are correct it does bow upwards a bit and it is considered normal.
10-21-2023, 03:08 AM | #11 |
Rep 1
Does anyone know where I can purchase set of BMW M Performance F82 M4 LED Illuminated Door Sills? I have been looking to replace mine due to wear but cant seem to find any online.
