Boost drops (slightly) after installing new CP
08-23-2015, 07:17 AM | #1 |
255
Rep 554
Drives: 2013 335is E93 6MT
Any idea why my peak boost would drop a full 1.0 psi after replacing the stock charge pipe? I'd hit 19.8 psi using the stock CP while waiting for the aftermarket CP to come in:
http://www.datazap.me/u/jasw/wedge-m...=0&data=4-6-20 Now after replacing the CP, the peak boost now hits 18.8 psi: http://www.datazap.me/u/jasw/3rd-and...og=0&data=4-20 Completely stock except for the CP, boost target is always 18.2, running a Wedge custom tune, and the only other difference is that I've been running an E25 mix to smooth out the negative timing corrections that can be seen in the earlier pull.
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings |
08-23-2015, 08:11 AM | #3 |
220
Rep 695
Boost target is 18.2 at 6.5k ROM, and requested load is pretty high. Not sure hitting 19.x was realistic since the car had a pretty significant throttle closure at nearly the same time. Seems much happier in the second log....does it feel different on the road?
Either way, targeting that kind of boost at high RPM on a stock car seems pretty aggressive. |
08-23-2015, 08:50 AM | #4 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
You're second log looks much better overall but your IAT is heading through the roof. You need a ATM stepped IC badly. Could just be the heat.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
08-23-2015, 09:43 AM | #5 | |
135
Rep 1,075
08-23-2015, 09:54 AM | #6 | |
220
Rep 695
08-23-2015, 10:18 AM | #7 |
2095
Rep 43,350
Check the o-ring at the throttle body and the o-ring at the tmap sensor. Also make sure your t-bolts/couplers are tight and correctly placed. If your CP has a meth bung make sure that's tight as well.
08-23-2015, 01:13 PM | #8 | ||
255
Rep 554
I'd been going into the low 160s with 3rd gear pulls here and there, but continuing on with the pull in 4th got things up to 180 (not to mention 130 mph in a 45 zone!). Yikes. That is the one remaining problem and of course Ken really can't do much about it on his end. The heat is oppressive down here. Of course, I don't drive WOT all of the time -- who does? -- so it's really only a problem on these pulls. Still, an FMIC is likely the next step. Along with DPs!
08-23-2015, 01:32 PM | #10 | |
Sua Sponte
1299
Rep 2,850
http://www.datazap.me/u/veloman62/lo...4&zoom=118-200
08-23-2015, 04:55 PM | #11 | ||
255
Rep 554
Why is the 18.2 boost target line on your log below the 20+ boost line? I don't get that.
08-23-2015, 06:57 PM | #12 | |
74
Rep 390
My Build Thread: http://www.e90post.com/forums/showth...8#post16918878 |
08-23-2015, 07:26 PM | #13 | |
Sua Sponte
1299
Rep 2,850
MHD's max target without MBoost is about 18.3. I get around that with the PID tuning done by BuraQ on my Cobb maps. I switched it all over via TunerPro and I had the mods to run it. I've since added the N20 sensor and incorporated it into my flash, skipping the N20 option on the flash install for more accurate reading. It will come in handy down the road.
08-23-2015, 07:38 PM | #14 |
2095
Rep 43,350
An improperly machined throttle body flange will cause a leak, especially if the flange is warped. The tolerances have to be really tight in order for the o-ring to seal properly.
08-23-2015, 08:26 PM | #15 | ||
135
Rep 1,075
08-23-2015, 08:38 PM | #16 |
31
Rep 370
I recently installed your charge pipe, the included o-ring was too fat... had to reuse the stock one.
08-23-2015, 09:09 PM | #17 |
52
Rep 278
08-23-2015, 09:13 PM | #18 | |
2095
Rep 43,350
08-23-2015, 09:53 PM | #19 | |||
220
Rep 695
08-24-2015, 05:27 AM | #20 |
255
Rep 554
Not sure what you're getting at -- true, the post-new CP loss of boost was in the area exceeding target, but it was exceeding target before with the stock CP. How could the car not have been set up correctly when it was stock?
08-24-2015, 05:34 AM | #21 |
255
Rep 554
So are you saying that this is the most likely reason for the 1.0 psi loss at peak boost? I certainly can't tell if the throttle body flange on the new CP is warped or otherwise improperly machined -- it goes on and is tight. I'm not sure how I can tell the company this -- I brought the car to their shop after noticing this slight drop and they said everything was fine with the CP.
08-24-2015, 07:19 AM | #22 | |
220
Rep 695
Having said all that, are you sure you're comparing apples to apples? The two individual logs you posted were collected over two weeks apart, are using different fuel mixtures, and appear to be using different tune revisions. Seems plausible an attempt to reduce the boost overshoot may have been made between your v1.1 and v3 iterations. |
