08-16-2015, 04:40 PM | #1 |
Rep 32
Oil change
I am planning to do an oil change for my M235i. How much oil should I plan to buy? I read 7qt somewhere.
Btw, this is my first car without a dipstick so once I start adding oil after I drain the old oil out, when do I know I have added enough? Is the only way to get in the car, start the engine and wait for the electronic dipstick to perform a check? |
08-16-2015, 05:05 PM | #2 | |
1399
Rep 5,262
08-17-2015, 04:07 PM | #5 |
310
Rep 886
The BMW branded oil is now sold in liter bottles. Buy 7 liters, put 6 in, get the engine warm and check the level. Odds on, you'll find it reads at Max.
The sump is 7 quarts. There's some holdup when you drain it, especially if you do it on ramps, and 6 liters will usually do just fine. Put the leftover liter in the trunk.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/BimmerTech amp, Enhanced BT
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi |
08-17-2015, 05:00 PM | #6 | |
Rep 32
Having no dipstick is just weird. I am coming from an Audi S4 that also had an electronic dipstick, but there was an actual dipstic slot in the engine and you could buy a dipstick for $15 and plug it in. I am surprised that this is not an option for the Bmw |
01-31-2016, 08:04 PM | #7 | |
15
Rep 71
Thanks. |
01-31-2016, 08:16 PM | #8 | |
3074
Rep 5,577
01-31-2016, 08:48 PM | #9 | |
1399
Rep 5,262
else when the oil starts to drip it will start falling onto the cover liner... |
01-31-2016, 11:12 PM | #10 | |
3074
Rep 5,577
http://formafunnel.com/ |
02-01-2016, 03:26 AM | #11 | |
310
Rep 886
