Coby Wheel
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > Regional Forums > CANADA
      08-03-2015, 03:27 AM   #1
alvinsl
9
Drives: m4
Is adaptive led headlight fully enabled in canada ?
Hi everyone !
I'm picking up my m4 in August.
Just curious if the adaptive led equipped on Canadian cars fully enable with beam split and etc functions or is it like the USA spec car with only high-beam assistance enabled.
Thank you
      08-03-2015, 08:57 AM   #2
pokerface
pokerface's Avatar
430
Drives: F25 X3 N20 / F80 ZCP
it will be the same as US Spec. I've been reading the coding discussions and it seems like it's still ambiguous what combo of options you need in order to have the necessary hardware to activate via coding.
      08-03-2015, 09:01 AM   #3
alvinsl
9
Drives: m4
Thank you for the respond.
I was going through a similar thread in the general function and found out that it needs to be coded. Now more thing to worry about before my car arrives haha.
      08-03-2015, 02:40 PM   #4
pyceasyas123
pyceasyas123's Avatar
390
Drives: M3
believe you need the tech package to have the correct cameras and sensors for coding later.
      08-12-2015, 02:23 PM   #5
CanAutM3
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
Adaptive LEDs are active in Canada. But just as in the US, they only swivel around bends. You can code Variable Light Distribution (VLD) for the low beams and Anti-Dazzle High Beams (ADHB) for the high beams.
However, as alvinsl posted, you will need the Tech Package, if only for the stupid little button on the turn signal stalk. Since I have Speed Limit Info, I have the required camera. But since I don't have the stupid little button, I cannot code the ADHL .
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
      08-12-2015, 09:32 PM   #6
myzmak
Advocatus Douchebagus. Sex Marxist.
myzmak's Avatar
2415
Drives: Lucy.
2015 F80 M3  [10.00]
2013 MB E350 Wagon  [10.00]
Is there a clear way to code now? I have the tech package (but not speed limit info) and would try to get this coded if I can....
Drivin' Lucy
      08-13-2015, 06:12 AM   #7
CanAutM3
CanAutM3's Avatar
21117
This is the best "how-to" guide I know of:
http://f80.bimmerpost.com/forums/sho...&postcount=317
      08-13-2015, 02:27 PM   #8
coolmody
365
Drives: AW/SO F80 M3
Check with E92LNYCGY. I coded his car for this, but was never sure if it worked for him
I didn't check the tech pack option, so I can't test this for myself.
Tags
active led, beam shaping
f80post
