08-01-2015, 10:41 AM | #1 |
405
Rep 962
Interesting article about N20 fragility
08-01-2015, 10:25 PM | #4 | |
16
Rep 234
Let's see, BMW's engineers designed the engine to produce 245hp yet these clowns push it up to almost 400hp. Gosh, I wonder what happened? Morons. |
08-03-2015, 06:58 AM | #5 | |
327
Rep 1,490
There are 4 cylinder engines out there pushing more than 400 HP on stock internals. I agree the N20 is not in that category, but this is definitely interesting to note as many people on this side have been trying to push this motor.
Current: 17 Mustang GT no bmw
Gone but not forgotten: 07 E90 335I, 04 UA6, 95 E36, 04 EP3, 16 S550 EB, 14 F30 328I Stg 1, 08 E90 328I |
08-03-2015, 10:25 AM | #6 |
405
Rep 962
The HP/TQ values were excessive and I agree it's not BMW's fault. However, getting next to no oil pressure during hard turns and also on braking kind of is.
08-03-2015, 12:45 PM | #7 |
10
Rep 108
Drives: 2014 328i xDrive Sport Line
I think the key for me would be trying to resolve the oil pressure issues vs the Max power output. Tbh ~300/300 HP/torque is more than enough for me as a daily driver.
08-03-2015, 03:00 PM | #9 |
514
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
Just as long as you don't brake or turn hard
I agree... >300 ft-lb of torque to the wheels is way more than enough for daily driving. It's really nice to see someone is taking this motor to it's limit's and thoroughly analyzing the results. I'm really looking forward to seeing some of the build kits that come out for N20 in 5-10 years. I'll definitely be a customer |
08-03-2015, 11:50 PM | #12 |
265
Rep 807
I think some people are being a little harsh. The whole point was to push to the limit to vet the engine to back up their product, which is more than most vendors do.
While most n20/26's will never be pushed to these limits, it's important to know what the limits are. Specifically with oil pressure. Not only does oil cool, it lubricates. So it's important to keep the pressure up. What some fail to see is that you can get the same level of G's on stock motor with heavy suspension tuning and tires. It's a little disappointing that these motors aren't built to handle the power. A 30k dollar evo or wrx can handle more with less engineering. |
08-04-2015, 12:10 AM | #13 | |
2895
Rep 3,473
I had the full exhaust setup, the full intake setup, larger intercooler, and other bits, but the stock turbo and injectors can only pass so much air and fuel, and if you try to tweak the tune for more, you real quickly get way too lean and start wrecking things. Those engines dumped lots of fuel into the cylinders during acceleration to cool the mixture and everything else associated, the engine counted on that. With the Subies, you could add as much as 50-60hp with bolt-on mods on the stock turbo and injectors, which is fairly consistent with what we see here. If you want more, you need to start heavily modifying the car so it won't self destruct, which means larger turbo, bigger fuel injectors, bigger intercooler, higher flow fuel pump, etc. If you want to get to the 400hp range and keep the thing from grenading, you will need forged internals and all sorts of other stuff. A WRX engine won't do 400hp. An STI block (forged) will get close, but require some serious modification to get there, especially if you are after the elusive 400whp, that's a much larger turbo and lots of supporting mods. Although the Evo follows a similar theme, it's engine block was something a lot more special than the WRX or even the STI, it was a forged unit capable of much more HP without internal modifications. The Evo has traditionally been easier to get more HP out of than the subaru engines. Overall, I think you are overestimating what the subaru turbo engines are capable of, especially considering where the N20 is already at in terms of dyno numbers. |
