BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Double clutch for manual transmission
      01-23-2006, 05:26 PM   #1
btc
btc's Avatar
63
Drives: 06/330i/SB/TERA/AL
2006 330i  [0.00]
Is it necessary to double clutch every time you up shift and down shift?
Sometime I double clutch when down shift. I never double clutch for up shift, you have to be very quick for up shifting.
To all manual transmission owner, do you double clutch at all ?
      01-23-2006, 05:27 PM   #2
bavarian19
bavarian19's Avatar
Drives: Car
I dont do it ever. I dont even think you need to with today's manual transmissions.
I do of course rev match (and have perfected it since I got my car in September) when downshifting, but no double clutch. Unneccessary
      01-23-2006, 08:44 PM   #3
shimshimhada
shimshimhada's Avatar
Drives: Portal
It's unnecessary, but you can do it for downshifting to reduce the load on the synchros. Double declutching heel toe downshifting FTW!
      01-23-2006, 08:57 PM   #4
BMW0
BMW0's Avatar
Drives: AW E90 330i
2006 330i  [0.00]
Double clutching helps with transitioning to high revs (downshifting).
330i 6MT l 255 HP @ 5900 rpm 214 lb-ft Torque @ 3500 rpm l Alpine White l Beige l Aluminum l ZSP l 494 l PDC
"Freude am Fahren" = "Joy to Drive"
      01-23-2006, 09:21 PM   #5
db17k
Chicketeh china the chinese chicken, you have?
db17k's Avatar
34
Drives: 335ci hold out
2003 S2000  [0.00]
double clutching heel to toe is haaaarrrd! but awesome when you nail it coming out of a turn!
"In Soviet Russia car forks you!"
      01-23-2006, 09:22 PM   #6
shimshimhada
Drives: Portal
What...? Don't you mean BEFORE entering the turn?
      01-23-2006, 09:29 PM   #7
db17k
db17k's Avatar
34
2003 S2000  [0.00]
yes i'm drunk!
i only fooled around with it a few years ago and decided I'm gonna F up the transmission on my car if i keep this up.
      02-11-2006, 12:25 PM   #8
ACZakka325i
ACZakka325i's Avatar
277
Drives: 2 stroke
sorry, but what exactly is double cluthing? Is that when you put it into manual, and then from manual to another gear?
(Waitlist): #1 M2CSL
(Current): 2016 F15 X5 3.5xdrive - 2010 997.2 C4S Coupe
(Past): 2016 F30 340xi M-Sport -2013 535i xdrive
2008 E92 M3 - 2006 E90 325i
2002 E46 325xi - 1991 E30 325i
      02-11-2006, 12:32 PM   #9
ksfrogman
ksfrogman's Avatar
Drives: E90 330i 6MT
2006 330i  [0.00]
2006 330i  [0.00]
Only if your name is Lt. Frank Bullitt and you're chasing two hit men in a 1968 Dodge Charger.
      02-11-2006, 12:32 PM   #10
shimshimhada
Drives: Portal
You can only do it in a car with manual transmission.
Originally Posted by http://en.wikipedia.org/wiki/Double_declutch
The purpose of the double clutch is to match the speed of the rotating parts of the gearbox for the gear you wish to select to the speed of the input shaft being driven by the engine. Once the speeds are matched, the gear will engage smoothly. If the speeds are not matched, the dog teeth on the collar will "crash" or grate as they attempt to fit into the holes on the desired gear. A modern synchromesh gearbox accomplishes this synchronization automatically.
Easiest way to explain it is that you're using the clutch pedal twice for one shift up or down, instead of once.
      02-11-2006, 12:36 PM   #11
ksfrogman
ksfrogman's Avatar
2006 330i  [0.00]
2006 330i  [0.00]
The only time I double clutch is when I want to downshift more smoothly or don't want to slide in icy road conditions when downshifting.
      02-11-2006, 12:38 PM   #12
shimshimhada
Drives: Portal
The only time I double declutch is when I want to drive a 10-speed rig straight into my enemy's face.
