2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Coding: Folders visible, but no names
      07-19-2015, 08:47 PM   #1
amuzement
amuzement's Avatar
Drives: F22 228i M Sport
I have successfully saved all the files (FA, SVT, ncd) and am at the step where I have selected "Edit FDL". It takes me to the next screen where it shows the numbered folders (3000, 3001, 3003, etc.), but when I look in the "Funktionen" folder of 3000, all of the subfolders appear as periods (.). Is there a way to have names appear so I can edit the the files in them?
If I use TokenMaster's NCD/CAFD Tool, I can see the folders with names like it should be, but I don't know how to edit them (if it is even possible). They only appear as periods within the E Sys software.
Thanks in advance!
      07-19-2015, 10:09 PM   #2
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
Thanks in advance!
Do you read and follow this note?
* NOTE: E-Sys Launcher Car Series MUST be set to exactly match the car's chassis type you are coding (e.g. F01, F06, F07, F10, F12, F15, F25, F30, F82, F83, etc.). If after install it defaults to F999 and it cannot be changed, change PC Date ahead 4 days, then change E-Sys Launcher Car Series, then change PC Date back to current date. DO NOT craete .EST Token and PIN with PC Date advanced 4 days as the Validity Start Date for the token will be 4 days in the future.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      07-26-2015, 10:03 PM   #3
amuzement
amuzement's Avatar
Yup that was the exact problem. I have successfully coded the S55 ASD, Sport Display, tire temperatures, digital speed, and disclaimer removal. Thank you for everything, Shawn; I could not have done it without you.
Search this Thread:
Advanced Search
2addicts
