07-16-2015, 08:45 PM | #1 |
2465
Rep 9,004
Computer help!
Help!!
Computer is a Lenovo U410 I5 with 6GB of ram, running windows 8. unfortunately, it went into hibernation one day and decided not to wake up...ever. Sonthe problem is I cant recover the computer at all. Contacted Lenovo and bought recovery disk, and those didn't work, as the disk was defective. Had them send me another set, and the system will quit partially theough, do to a missing file/unable to read file. I even had a friend supply me with Windows 8.1 ISO, and I'm trying to use that. Here is the problem though, I can't format the drive. At all. defective harddrive, better software..what's going on? I have an 80GB I popped in and it worked to format windows and is installing it fine..but my 500GB took forever to even read, muchless attempt to install windows 8. Wtf is going on? |
07-16-2015, 08:51 PM | #3 |
7478
Rep 10,120
For starters get windows 7. Windows 8 is an absolute piece of garbage, it's pretty much windows ME all over again. And if a drive won't format then it is safe to say it is shot.
07-16-2015, 08:59 PM | #5 |
2465
Rep 9,004
07-16-2015, 09:07 PM | #6 |
Retired BMW Genius
2898
Rep 3,404
Sounds like your HD is on its last legs.
You need a Mac. I've converted three of my friends, and they are never going back. Last edited by The Automotive Enthusiast; 07-16-2015 at 09:08 PM.. Reason: Whoops, spelling. |
07-16-2015, 09:07 PM | #7 |
Warrant Officer
375
Rep 1,341
You should have a BIOS, it's based from the motherboard. The hard drive most likely went to crap and thus making not run any programs. You can possibly still save it and install another 500GB+ HD, and depending on the SATA ports available, hook the bad HD to it as well and maybe view the files.
Deleted, ATM I/C and tuned by B.R.R.
07-16-2015, 09:09 PM | #8 | |
2465
Rep 9,004
07-16-2015, 09:17 PM | #9 |
Warrant Officer
375
Rep 1,341
Damn, a laptop? It's anybodies game with those, as a lot of the parts are integrated. I'm really not too familiar with the repair of laptops. Hopefully someone else can guide you better with those.
07-16-2015, 09:27 PM | #10 |
7478
Rep 10,120
The hard drive will be a SATA drive and it is not built into the laptop. You can remove it and replace it. You can then buy a SATA reader. Basically you plop the drive into it like a NES cartridge and the connect it to your PC via USB. Most likely you will be able to at least get your data of off it.
07-16-2015, 09:35 PM | #12 |
2465
Rep 9,004
Already disassembled and harddrive removed.
So: 500GB HD Recovery disk don't work USB boot/Windows install takes forever to boot Attempted to reinstall windows from USB, but Windows installer cannot format drive 60GB HD Recovery disk don't work USB Boot/windows install works instantly Windows formatted drive just fine. Bad harddrive? |
07-16-2015, 09:41 PM | #13 |
85
Rep 707
Seriously...throw the HD/tower in the ocean and buy a Mac..problem solved for like 20 years. OR buy another PC and deal with the same sit every 5-6 years....Profit.
07-16-2015, 09:50 PM | #14 |
Free Thinker
16967
Rep 7,455
Hard drives are hard drives, Mac or not. They're just as likely to die in a Mac as they are in a PC. I use Windows and Mac all day long. Both have their bugaboos and both have their charms. But the hard drives are identical equipment. Buying a Mac won't prevent or even reduce hard drive failure.
07-16-2015, 09:57 PM | #15 | |
85
Rep 707
Nonsense. Not only is it way off, it's not in the same atmosphere. |
07-16-2015, 10:01 PM | #16 |
5330
Rep 1,912
You do realize Apple doesn't make its own drives right? They are samsung drives and yes I'm an Apple user.
07-16-2015, 10:03 PM | #17 |
derp
48
Rep 1,203
ITT: 2 people provide useful advice and everyone else jerks off Apple.
Taskmaster2465.00 |
07-16-2015, 10:05 PM | #18 | |
7478
Rep 10,120
Apple DOES NOT make its own components. CPU is Intel, video cards are nvidia, hard drives are what ever vender has cheapest, and mother boards are proprietary but made at FOXCONN (China) using standard components. The only thing that makes a Mac so different than a PC is the OS. Yes the MAC will fail like any other PC. Components do not last forever. Last edited by Delta0311; 07-16-2015 at 10:26 PM.. |
07-16-2015, 10:15 PM | #19 |
410
Rep 841
The 500GB disk probably has slow read speed. Do you know what the read write speed is?
The 60GB disk is probably faster. That's my guess. Get yourself a 128GB SSD and install your windows there. Newegg.com always have the best deals
WHO'S THE BOSS
07-16-2015, 10:16 PM | #20 | |
85
Rep 707
Look...I get it. Using mac isn't mainstream but PC is dead...beleedat. |
07-16-2015, 10:19 PM | #21 |
5330
Rep 1,912
OP just buy a new drive, put windows on it then install the old drive as a secondary drive and see if you can pull anything off it and call it a day. Or you can even get one of those drive cloners off Amazon for $20 and see if you can clone the old drive onto a new one. Drives are cheap.
07-16-2015, 10:21 PM | #22 | ||
410
Rep 841
1st) i don't like the term PC. They're all PC to me. 2nd) i have both. I built my Windows machine with quality parts and it works great. 3rd) i like both but if i were to pick only one, i'd go with the Windows. Because of its open flexibility. Apple controls too much.
WHO'S THE BOSS
