BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > What is so important about breaking in the engine
      01-23-2006, 12:16 AM   #1
HoosBMW
A ROOM WITH A MOOSE!
HoosBMW's Avatar
Drives: waiting on the replacement
2007 335I  [0.00]
2006 330I  [0.00]
Hey,
I know a lot of people talk about breaking in the engine....
What i want to know is why....and what does it affect if you do or don't.
Not trying to be a smart a**...just wondering...I have heard so many things...i just want to know exactly what is effected...thanks a lot guys..
by the way everyone in this forum is freakin' awesome....you guys are so helpful.... :rocks:
      01-23-2006, 07:51 AM   #2
Meatnog
7
Drives: 2006 330i Sedan
Depends on how long you're planning on keeping the car. I keep hearing from BMW and dealers that there is no official breakin. But BMW only considers the 'lifespan' of the car to be 100K miles.
So, basically, from what we've gathered is that up to 100K miles, there's really no difference. Over that, you may get some extra life out of the engine.
2006 330i Sedan: Monaco Blue, Beige/Walnut, Premium Package.
      01-23-2006, 07:58 AM   #3
SteveMD
SteveMD's Avatar
193
Drives: 2016 F10 535i MSport
Most manufacturers don't require this any more. It used to be a ritual for every new car. Since BMW puts it in the user manual, I will be doing it.
One thing I always do is change the oil and filter at 500 miles. Just in case there's a metal shaving or two in there.
2006 E90 330i (retired)
2009 E90 335i (retired)
2012 E70 X5 50i M Sport (retired)
2016 F10 535i M Sport
      01-23-2006, 12:57 PM   #4
shragon
Moderator
shragon's Avatar
497
Drives: BMW
i'm following it, since bmw put it in the manual. but when i asked my sales guy (a long time bmw sales person), he said there really isn't much of a break-in period any more for new bmw's. he just said, try to be some what gentle with it for the first 1000 miles.
      02-17-2006, 12:02 PM   #5
06330i
fresher den you
06330i's Avatar
Poland
34
Drives: 2004 x3
2006 E90, 330i  [0.00]
yea u arent supposed to rev the engine over soo many rpm's, i cant remeber exctly what it is, the engine runs real rich,when it first breaks in
      02-17-2006, 02:05 PM   #6
vladinecko
vladinecko's Avatar
Drives: '11 E92 M3
2011 BMW M3  [9.00]
2008 BMW 335i  [0.00]
2006 BMW 330i  [0.00]
1994 BMW 325i  [0.00]
think of it as buying a pair of new shoes. you gotta walk careful in them because if you start running a marathon right off the bat, they will hurt your feet really bad. you gotta wear them down a little, make 'em loose, stretched and adjusted to be able comfortably walk in them.
same with the engine, there are some moving internal parts that are rubbing against other parts so you gotta take it easy at the beginning to give those parts time to adjust and smooth out. if you push it too hard during break-in period, you risk making things way too loose.
i think it's also some kind extended testing period where they're basically saying, if nothing major happens to the engine/breaks etc. in the first 1200 miles, it is safe to assume that there are no significant manufacturer defects in the car and therefore you can feel free to push it to the limits.
2011 E92 M3 - IB/Beige/Sycamore Wood/6MT/EDC/ZPP2/Nav/PDC/Heated Seats/iPod-USB/Enh. Audio
2008 E92 335i - Montego Blue/Black/Gray Poplar/6MT/ZPP/ZSP/Nav/PDC/Heated Seats/HDRadio/iPod-USB - Sold
2006 E90 330i - Mystic Blue/Black/Aluminum/6MT/ZPP/iDrive/PDC/Heated Seats/Sat. Prep - Sold
1994 E36 325i - Boston Green/Beige/Automatic/ZPP/Heated Seats/Premium Sound - Sold
      02-17-2006, 02:13 PM   #7
sdorn
sdorn's Avatar
26
Drives: 2006 Jet Black 325i
The manual says to vary engine speed for the first 1,200 miles. Also, keep the revs below 4500 and the speed under 100mph.
I have also read some interesting articles that seem to indicate that driving a car delicately during the break-in period leads to lower performance, and that driving the car extremely hard during breakin is actually more conducive to the car having better performance.
I had a custom built motor put in my Mustang, and the engine builder actually broke the engine in on the dyno doing complete runs to the redline. He started off pulling up to lower rpms, then worked his way up to doing several redline runs. That car runs like a champ, although I have only put another 12,000 miles on it since the new engine went in.
2008 Sparkling Graphite 535i
2009 Land Rover LR2
2003 Porsche 911 Turbo (SOLD)
2006 Jet Black 325i (SOLD)
2001 Bullitt Mustang (450rwhp - SOLD)
      03-24-2006, 03:36 PM   #8
Zartok
Drives: 320d M Sport
Breaking in an engine too gently can affect performance. The ECU is learning how the engine is being used so for better throttle response it's worth varying speed regularly rather than cruising during the break in period.
      03-31-2006, 10:54 AM   #9
xenocide
Car Guy
Drives: 330i
The real deal on engine break-in . .
Here is the best information I have found so far on breaking in an engine. Read the long post towards the bottom; especially the technical section:
http://member.rivernet.com.au/btaylo...kInPeriod.html
From the article:
The Theory. The primary goals of engine break-in are: 1) achieving a
good seal between the piston rings and cylinder walls, and 2) allowing
the engine to operate correctly throughout its RPM range. The major
enemy during the break-in period is localized heat buildup, mainly in
bearing surfaces (most notably the crankshaft bearings).
It's a good read!
      04-03-2006, 12:27 PM   #10
donger274
Drives: honda
also got to break in your clutch for you 6mt out there
