07-14-2015, 12:52 PM | #1 |
2241
Rep 2,370
M2: The aggressive design of the sunken in headlight
The aggressive creases of the M2 headlight
So, from analyzing multiple pictures from different angles, I believe I have discovered how the design of the corner of the headlight will be executed. It will be sunken into the body work, like the M3/4, however, instead of the line extending beneath the headlight, the line from the corner of the headlight will extend into the bottom of the headlight. I found the perfect image here: I showed this to Artemis , and he did his magic negative work and uncovered an even clearer view: Here, the line is drawn over: Beneath the sunken in headlight will be a flat, yet protruding area, making the intakes look MASSIVE. It should be a very clean and super aggressive execution. Cheers |
07-14-2015, 02:08 PM | #4 |
5311
Rep 5,824
Making sure that all the new MINI's give you goosepimples.
The M850i is evidence that BMW have got their mojo back when it comes to dynamic sports cars...
07-14-2015, 02:09 PM | #5 | |
3160
Rep 9,134
07-14-2015, 02:09 PM | #6 |
3160
Rep 9,134
07-14-2015, 02:20 PM | #7 |
253
Rep 471
"goosepimples" sounds like impetigo or something. I guess what you're hinting at, is that all the new cars will come with S. pyogenes-inoculated constrast stitching. That explains the seat covers in the M2 test mules.
JK |
07-14-2015, 02:21 PM | #8 | |
Moderator
29334
Rep 13,093
In case you missed it in another thread: due to the size of the M2 front intakes, BMW M even moved the headlight washers closer to the head light cluster (indicated in red in the third small picture). And don't let the camo fool you. To my eyes, the triangular shaped camo inside the intake (indicated in red in the fourth small picture below) is merely a camo add-on that hides a slightly toned down V-shape intake design of the BMW Vision Concept GT6. I doubt that the high crease line showing the intake lines would be camo to mislead the onlookers. Yup, this car is gonna be applauded once the camo is taken off. Compare with the BMW Vision Concept GT6 (note: the hood design will be the modern one, i.e. a horizontal line that does no longer 'touch' the kidneys + BMW roundel no longer on the hood itself): Compare with the M235i Racing (lower position of the headlight washers, as the intake has a smaller size):
///M is art ↔ Artemis
07-14-2015, 03:17 PM | #9 |
354
Rep 1,405
Well, now we know it has the "Cold Weather" option. I wonder if the back seat folds down and heated seats comes with that?
I hope so. Even strippers have to be somewhat civilized. Heated steering wheel? It can't weigh that much! |
07-14-2015, 03:28 PM | #10 | |
Moderator
29334
Rep 13,093
07-14-2015, 03:30 PM | #11 |
253
Rep 471
hmmmmm....... I disagree, I think the camo triangle is legit. My guess is that the the strip of camo found above the triangle (and underneath the blue line above above the triangle), is hiding the non-functional, aesthetic parts of the upper half of intake.
07-14-2015, 03:46 PM | #12 |
5311
Rep 5,824
Yes and they are working on the M2 Teasers right now.
07-15-2015, 08:23 AM | #15 |
5311
Rep 5,824
They will be ready when they are ready...Not before.
07-15-2015, 08:37 AM | #16 |
991
Rep 1,495
My (much-loathed) disappointment about the seats aside, the potential aggressiveness of this aero kit is getting me really excited.
I have goose pimple.
Then - E53, E85, E92, E82, F15, F80, G01
Now - F97, Macan S |
07-15-2015, 09:01 AM | #17 |
3160
Rep 9,134
07-15-2015, 09:58 AM | #18 |
36
Rep 115
07-15-2015, 10:10 AM | #20 |
1120
Rep 1,644
I can already see the disappointment incoming for the teaser when people get what looks like pro testing footage with a camo'd car like the 1M. Will be awesome none the less but don't expect to see any new details on the car except maybe some more interior shots.
07-15-2015, 02:00 PM | #21 | |
5311
Rep 5,824
