Cobb charge pipe fitment issues
07-13-2015, 02:33 PM | #1 |
247
Rep 416
Hey guys, I blew my OEM charge pipe a few days ago and ordered a Cobb pipe to replace it. Upon attempting to install the new one, it doesn't seem to want to fit completely onto the throttle body. Does anyone have any insight as to what I might be doing wrong?
It doesn't appear to be caught or stuck on anything and it just won't slide up any further. |
07-13-2015, 03:02 PM | #2 |
730
Rep 1,815
Just installed mine last week. It takes a bit of wiggling but it is a nice tight fit. Make sure you pull the O-ring out of the stock pipe and lightly coat the mating surface with a little fresh oil. ( not dripping but light surface coat) make sure you get it all the way on before snapping the clip back on it.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
07-13-2015, 03:05 PM | #3 | |
648
Rep 2,013
335i e92 TPC 19Ts
07-13-2015, 03:13 PM | #4 |
247
Rep 416
07-13-2015, 03:14 PM | #5 | |
247
Rep 416
07-13-2015, 04:03 PM | #6 |
BimmerPost Supporting Vendor
24279
Rep 190,975
This issue has been reported multiple times with Cobb charge pipe.
07-13-2015, 05:21 PM | #7 |
247
Rep 416
07-13-2015, 05:22 PM | #8 | |
3441
Rep 79,211
Return the Cobb and Buy an ER Pipe. Cobb CP has fitment problems, every time. These should be fitting much easier for those that said it's tight. They are too tight and put a lot of pressure on the TB. As far as O Ring, supposedly its the same as the oil filter O Ring (Dont shoot the messenger). |
07-13-2015, 05:47 PM | #10 |
24279
Rep 190,975
Most people decide to get another brand.
Evolution Racewerks is the most popular option. VRSF is a very good option as well.
07-13-2015, 06:21 PM | #11 |
648
Rep 2,013
Wherabouts in md?
335i e92 TPC 19Ts
07-13-2015, 06:30 PM | #12 | |
247
Rep 416
I'm down in southern MD, near Waldorf. What about yourself? |
07-13-2015, 06:45 PM | #13 | |
648
Rep 2,013
335i e92 TPC 19Ts
07-14-2015, 06:07 AM | #15 |
85
Rep 707
That surprises me as Cobb has always made high-quality products. That being said, I bought a VRSF and used the Cobb instrux. for install because they are very close in design. If I recall, the VRSF was snug but I thought I remembered a gap. It took a long time for me to properly orient the CP against to the TB...just make sure it's flush, you have the O ring and seat the C-clip. Take it out and drive it. You will immediately know if it's leaking or not.
re you able to seat the C clip as it is now? |
07-14-2015, 06:38 AM | #16 | |
730
Rep 1,815
You do need to O-ring for a proper seal recheck the original charge pipe for it.
07-14-2015, 07:26 AM | #17 | ||
247
Rep 416
Nope, the pipe wasn't sliding up enough to seat the C clip. It would just pull right back off. Quote:
07-14-2015, 07:31 AM | #18 | |
730
Rep 1,815
07-14-2015, 09:30 AM | #19 | |
Joint Chiefs of Staff
4920
Rep 115,999
There are a few thread on here of people reporting the same issues. I am not sure what the actual physical issue is, but may be a batch issue. Best to email COBB support to get it straightened out. Also make sure o-ring is transferred and properly seated. Mike |
08-01-2015, 03:24 PM | #20 |
93
Rep 151
Don't mean to revive a dead or dying thread but I recently bought the Cobb charge pipe and had a similar issue.
The solution is to remove the 4 bolts that connect the throttle body to the intake manifold. Then attach that to the charge pipe. Then re-orient the charge pipe and throttle body and rebolt the throttle body with the charge pipe attached. I figured this out after hours of trying to muscle the charge pipe on last night. As someone else said, it is just a tight fit. hope this helps. |
08-02-2015, 01:25 PM | #21 |
71
Rep 244
I didn't have to unbolt my throttle body. I used a long pry bar to GENTLY nudge the cp (at the map sensor fitting) onto the throttle body while wiggling it up and down and it popped right on.
